Hi Everyone !
After some research in the forum , I´ve found this to use batch to use ECM Tools in within GameEx
The idea of JK1974 is great , and helped me a lot to find the answer for my problem.
Based on his code , I´ve modified it to apply better to my situation.
So here´s my code
@echo on
set directory=%1
set directory=%directory:~1,-1%
set file=%2
set file=%file:~1,-1%
"C:\Playstation\packiso\unpakkIso.exe" "%directory%"
"%ProgramFiles(x86)%\Daemon Tools Lite\daemon.exe" -mount 0,"%directory%\%file%"
C:\Playstation\ePSXe.exe -nogui -slowboot
I´ve made just a few changes... :lol:
Well , I need help in the following.
This batch file does it :
1-Run Unpackiso to Unpack my game and get it ready do be mounted by Daemon Tools
2-Mount the ISO file
3-Run epsxe.
My problem is , after unpacking the ISO , the BIG *.bin file stays in the folder.
And if I want to play the same game again, I will have to wait (a lot) the unpackiso process finish again.
I want that the Batch file check if a *.BIN file is present , and if yes skips the process of unpackiso. Going right to the Daemon tools step.
And after that , mount the *.cue that is already present in the directory.
Thanks to everyone !
@echo on
set directory=%1
set file=%2
What are the input file names are they *.bin files?
If they are you could use:
IF NOT EXIST %file% GOTO unpack ELSE GOTO end
:unpack
GOTO end
:end
Check out
http://www.computerhope.com - for more batch file commands
