Hi i have been using Gameex Successfully for years!
i love it and think its great!
however i recently got an old computer vaio rs630g that i wanted to run gameex on and for the life of me i cant figure out why it wont run!
I installed it have all the direct x installed the .net updates.. go through config but everytime i either try yo set up emulators OR just try launching it without emulators it locks up almost my whole system and get no launch screen whatsoever!
instead i just hear a weird sound coming from my hard drive like its trying to search the same area over and over. Check the drive its good, tried uninstalling and reinstalling. tried OLD versions of gameex tried new one have NO idea what is going on!
its not a processor or ram issue its a 3.0 and 2.5 gigs of ram win xp system with all drivers updated and installed..
any clue?
Im getting really frustrated becasue it should be working.. it just isnt.
thanks
any clue?
thanks
So, You don't think its a hardware issue because you hear the drive paging back and fourth trying to read data?
Its there anything else you should mention, like if its an nlighted OS or tiny build of xp?
