When I exit VPinball for a couple of seconds it shows the box
quit to editor
quit to windows
is there a way to stop this showing
thanks
Not sure it's the only way, but I use an advanced config.
Mapping Off Exit (ESC+Q).txt
Just rename the file with an .ini extension, and put it in GameEx\CONFIG\EMULATORS.
Run the Advanced onfiguration program, and on the 3rd page of your emulator config is the option 'Advanced Config'
Choose the Mapping Off Exit (ESC+Q).ini config from the drop down menu.
Also, I have a script that I use to hide all of the windows while VPinball is loading. If you are interested, you can find it here:
http://www.gameex.info/forums/index.php?showtopic=3&st=80&gopid=56685entry56685
Post here if you need help with the loader.
Thankyou all working now
cheers
