Any idea as to why video plays so low (audio) when played in gameex? If the roms and music plays at a comfortable level most video files will play so low that I have to crank my speakers to the max. I realize I could adjust the gameex audio level but i was hoping that their is a "fix" to my issue. If I play the same files in VLC the audio levels are at their normal level, it only happens when running the files in gameex.
Its related to whatever codecs you have installed. GameEx just uses standard directx filters depending on what you have installed. Whereas VLC has its codecs built into the app. Check you codec settings and codec pack. Vista codec pack is the currently recommended codec pack (regardless of whether you have vista). Make sure you uninstall existings codecs first before using something else.
