Hey gang,
I'm making some changes to my theme and had a few questions:
Is it possible to make the selector bar transparent for items that are not selected?
Is it possible to have more than one image/video box? One that would display the preview video, and one for marquees?
I'm was playing around with AHK to make it easier to scroll through the letters with the below code. It works, but not 100% as sometimes it won't do anything, or sometimes it will skip pages. Also when using AHK my CapsLock LED flashes. Is this normal? Is there a way to disable this?
#SingleInstance Force
#IfWinActive GameEx
Left::
send {A down}{Left down}
send {A up}{Left up}
return
Right::
send {A down}{Right down}
send {A up}{Right up}
return
Anyone have any tips or input for me?
Thanks guys!
Yes just use a black image for the unselected png.
With version 4 themes.
Hey Tom!! :D
I think my theme is, or was a Version 2 theme that I hacked and slashed at. How can I convert it to a v4 theme, or add the second image box to my theme?
Also can the video previews be stretched to fill the box?
Just a preview of what I'm working on...
Can I disable the top menu? And can I stretch the images and videos to fill the box?
Try:
SetTitleMatchMode, 2
Return
#IfWinActive GameEx
Left::
return
Right::
return
Code is untested.
Edit: You may also want to look at SetKeyDelay
