17th November 2005
- GameEx 5.17
  • Ability to increase or
    decrease font size
  • Random Startup Videos
  • Fixed video sizing and
    positioning issues with Startup Videos
  • Ability to confirm dialog box
    with left mouse button
  • New in Videos Module - Play
    all videos in a folder randomly
  • New Jukebox mode - ability to
    use Jukebox without reliance on Windows Media
    Player (scans tags)
  • Setting now in configuration
    to start Full Screen or Windowed
Is there anything I should know about installing the new version? Do I have to uninstall the previous version? Do I just install over the top? Will it keep my current config files?
Just install over the top, it automatically upgrades your config files. It makes a backup too just in case. If your manually editing the ini files instead of using the config, you will keep all the settings but you will loose any blank lines or comments that you put in yourself. Not a biggie, just letting you know.
When a 2.0 framework suport Tom? I can´t play because the same error of everytime...
Thanks a lot.
Can't say as its not a simple fix, although its currently top priority. You could always just uninstall 2.0 though, no?
Yes Tom, but i have installed the beta 2.0 framework and Gameex recognice me this and don´t run. Its a big problem, i tried everything but still don´t running.
Gameex is a great program, but i cant play it... :(
Thanks a lot for your hard work!!!
