Hello,
I have two problems...and I'm asking for your help.
I have a fresh install of Vista 32-bit and the latest version of Future Pinball. The problem is with the key, I can change them and everything but when I start any pinball (even a new one with almost nothing on it), only the nudge key works (space, z, /). I can not insert coin and so I don't know if the plunger, start, left and right flipper also work or not. Anyone encountered this problem?
The next problem is really weird. I just recently bought the Antec Fusion with the VFD. Like before it's a fresh install of Vista 32-bit. But with the vfd usb connector plugged on my motherboard, the usb game controller doesn't work. It's like detecting the controller 5 seconds later it's like I've unplugged the controller (even if it's plugged), and it starts again. I can hear the sound of the device being plugged and then unplugged, plugged and then unplugged, again and again.
I've checked the game controller in the control panel, it appear and then dissapear, every 5 second aproximately. If I use a usb hard drive it works fine. If I unplugged the vfd usb cable from the motherboard everything work fine (except the vfd of course).
Any idea?
Thanks for any help,
Yves
