Ok, out of the blue Gameex stopped working and I have no idea why. I didn't delete anything, rename anything, move anything, it just stopped working. I decided to update to the latest version and it didn't fix the problem. Here's what it keeps saying:
15:40:04.2 6/24/2009: GameEx: Version 10.15: Starting L
15:40:04.2 6/24/2009: Operating System Platform: Win32NT
15:40:04.2 6/24/2009: Operating System Name: Windows XP
15:40:04.2 6/24/2009: Operating System Version: 5.1.2600
15:40:04.2 6/24/2009: Checking for versions of .net Framework installed
15:40:04.2 6/24/2009: .net Framework 1.1 Installed
15:40:04.2 6/24/2009: .net Framework 2.0 Installed
15:40:04.2 6/24/2009: Intel® Celeron® CPU 2.80GHz, 1023MB
15:40:04.2 6/24/2009: 2.8Ghz
15:40:04.2 6/24/2009: Running Randomize()
15:40:04.2 6/24/2009: Loading PlugIns
15:40:04.6 6/24/2009: Checking for applications to Launch On Startup
15:40:04.7 6/24/2009: Running Misc startup tasks
15:40:04.7 6/24/2009: Setting Menu types
15:40:04.7 6/24/2009: Opening Configuration File
15:40:04.7 6/24/2009: Getting Configuration Values
15:40:04.7 6/24/2009: Using Theme: Default - Future Retro
15:40:04.7 6/24/2009: Checking for alternate Image Directory for Theme: Default - Future Retro
15:40:04.8 6/24/2009: Launching HideOS.exe
15:40:04.8 6/24/2009: Initialising Video/MNG DLL's
15:40:05.0 6/24/2009: GameEx will check for media insertion (may affect performance)
15:40:05.0 6/24/2009: Hiding Taskbar
15:40:05.0 6/24/2009: Is Media Center running?
15:40:05.0 6/24/2009: Checking/Creating LCD Registry values
15:40:05.1 6/24/2009: Check Media Center Exit/Start Mode
15:40:05.1 6/24/2009: Media Center Mode 2
15:40:05.3 6/24/2009: Video previews on. Warning: Only recommended on modern systems
15:40:05.4 6/24/2009: Custom Game Device Input enabled: Getting custom codes
15:40:05.5 6/24/2009: Snap Delay set to: 2
15:40:05.5 6/24/2009: Get other settings
15:40:05.7 6/24/2009: Desktop set to Hide ICONS and set Background to Black
15:40:05.7 6/24/2009: Set: Find emulator artwork on best match basis
15:40:05.7 6/24/2009: Start work for Form
15:40:05.7 6/24/2009: Getting Original Screen Size
15:40:05.7 6/24/2009: Opening Database Connection
15:40:05.8 6/24/2009: --**--
15:40:05.8 6/24/2009: Error: Unrecognized database format 'C:\Program Files\GameEx\DATA\data.mdb'.
15:40:05.8 6/24/2009: at System.Data.OleDb.OleDbConnectionInternal..ctor(OleDbConnectionString constr, OleDbConnection connection)
15:40:05.8 6/24/2009: at System.Data.OleDb.OleDbConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningObject)
15:40:05.8 6/24/2009: at System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnect
ion owningConnection, DbConnectionPoolGroup poolGroup)
15:40:05.8 6/24/2009: at System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection)
15:40:05.8 6/24/2009: at System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory)
15:40:05.8 6/24/2009: at System.Data.OleDb.OleDbConnection.Open()
15:40:05.8 6/24/2009: at t.a(Boolean A_0, String A_1, Boolean A_2)
15:40:05.8 6/24/2009: at t..ctor()
15:40:05.8 6/24/2009: Disposing Plugins
15:40:05.8 6/24/2009: GameEx is exiting with errors
15:40:07.5 6/24/2009: ERRORS DETECTED: EXITING
Also, before all this happened, my gameex registration key stopped working. Tom told me to launch the file, but how do you launch a .gxkey file? Any help would be greatly appreciated.
That's a registry file, so you should be able to just double click on it. If that doesn't work, you might try renaming it to ".reg". Alternately, you can open regedit and import the file.
GameEx appears to be puking on the main database. I don't know why it would be a problem though.
Thanks, for some reason it worked now. I didn't have to rename it or anything. Very odd. As for the database problem, I had to copy and paste a new database file from an older Gameex to get it to work. Strange, one minute Gameex was working fine, the next it wasn't. Computers are such a pain in the arse sometimes.
