every time i click on "play this game" it looks like it will start and then goes back to the play this game screen. I can't play any games.
help please
thanks
is this what you need to help?
08:09:11.6 5/25/2009: GameEx: Version 10.09: Starting Log
08:09:11.6 5/25/2009: Operating System Platform: Win32NT
08:09:11.6 5/25/2009: Operating System Name: Windows XP
08:09:11.6 5/25/2009: Operating System Version: 5.1.2600
08:09:11.6 5/25/2009: Checking for versions of .net Framework installed
08:09:11.6 5/25/2009: .net Framework 1.1 Installed
08:09:11.6 5/25/2009: .net Framework 2.0 Installed
08:09:11.6 5/25/2009: Pentium® Dual-Core CPU E5300 @ 2.60GHz, 1917MB
08:09:11.6 5/25/2009: 2.6Ghz - 2 Cores or CPU's
08:09:11.6 5/25/2009: Running Randomize()
08:09:11.6 5/25/2009: Loading PlugIns
08:09:11.6 5/25/2009: Checking for applications to Launch On Startup
08:09:11.6 5/25/2009: Running Misc startup tasks
08:09:11.6 5/25/2009: Setting Menu types
08:09:11.6 5/25/2009: Opening Configuration File
08:09:11.6 5/25/2009: Getting Configuration Values
08:09:11.6 5/25/2009: Using Theme: Default - Deep Purple V1
08:09:11.6 5/25/2009: Checking for alternate Image Directory for Theme: Default - Deep Purple V1
08:09:11.6 5/25/2009: Using Images from theme: Default - Deep Purple\MEDIA\
08:09:11.6 5/25/2009: Launching HideOS.exe
08:09:11.6 5/25/2009: Initialising Video/MNG DLL's
08:09:11.6 5/25/2009: GameEx will check for media insertion (may affect performance)
08:09:11.6 5/25/2009: Hiding Taskbar
08:09:11.6 5/25/2009: Is Media Center running?
08:09:11.6 5/25/2009: Checking/Creating LCD Registry values
08:09:11.6 5/25/2009: Check Media Center Exit/Start Mode
08:09:11.6 5/25/2009: Media Center Mode 2
08:09:11.6 5/25/2009: Video previews on. Warning: Only recommended on modern systems
08:09:11.6 5/25/2009: Snap Delay set to: 2
08:09:11.6 5/25/2009: Get other settings
08:09:11.6 5/25/2009: Desktop set to Hide ICONS and set Background to Black
08:09:11.6 5/25/2009: Set: Find emulator artwork on best match basis
08:09:11.6 5/25/2009: SlikStik support enabled
08:09:11.6 5/25/2009: Start work for Form
08:09:11.6 5/25/2009: Getting Original Screen Size
08:09:11.6 5/25/2009: Opening Database Connection
08:09:11.7 5/25/2009: Initializing Component
08:09:11.7 5/25/2009: Retrieving resolution setting
08:09:11.7 5/25/2009: Initialising Windows Media Player Component
08:09:11.7 5/25/2009: MAME Path is: C:\mame
08:09:11.7 5/25/2009: MAME EXE file is: mame.exe
08:09:11.7 5/25/2009: ROM Path is: C:\mame\roms
08:09:11.7 5/25/2009: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
08:09:11.7 5/25/2009: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
08:09:11.7 5/25/2009: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
08:09:11.7 5/25/2009: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
08:09:11.7 5/25/2009: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
08:09:11.7 5/25/2009: Loading Controls.ini map file
08:09:11.7 5/25/2009: Snap Path is: C:\mame\snap
08:09:11.7 5/25/2009: AVI Snap Path: Not Found
08:09:11.7 5/25/2009: Flyer Path is: C:\mame\flyers
08:09:11.7 5/25/2009: Cabinet Path is: C:\mame\cabinets
08:09:11.7 5/25/2009: Title Path is: C:\mame\titles
08:09:11.7 5/25/2009: PCB Path is: C:\mame\pcb
08:09:11.7 5/25/2009: Artwork Preview Path is: C:\mame\artwork
08:09:11.7 5/25/2009: Panel Path is: C:\mame\cpanel
08:09:11.7 5/25/2009: Manual Path: Not Found
08:09:11.7 5/25/2009: Icon Path is: C:\mame\icons
08:09:11.7 5/25/2009: Marquee Path is: C:\mame\marquees
08:09:11.7 5/25/2009: Loading Custom Emulators
08:09:11.8 5/25/2009: Using 2D Animations
08:09:11.8 5/25/2009: Using General Font: Verdana
08:09:11.8 5/25/2009: Using Title Font: Trebuchet MS
08:09:12.5 5/25/2009: Initialising DirectDraw
08:09:12.5 5/25/2009: Creating DirectDraw Device
08:09:12.5 5/25/2009: Using Device: Intel® G45/G43 Express Chipset
08:09:12.5 5/25/2009: 235mb video memory available
08:09:12.5 5/25/2009: Setting Resolution to 1920x1200 32 bit color
08:09:12.5 5/25/2009: Creating DirectDraw Surfaces
08:09:12.5 5/25/2009: Creating Primary Surface - Full Screen Mode
08:09:12.5 5/25/2009: Creating Back Buffer
08:09:12.6 5/25/2009: Loading graphic Surfaces
08:09:12.6 5/25/2009: Display is running at: 1920x1200 32bit color, 60hz
08:09:12.6 5/25/2009: Creating Surfaces Flags
08:09:12.6 5/25/2009: Creating Surfaces Misc and Dialogs
08:09:12.7 5/25/2009: Creating Surfaces Volume
08:09:12.7 5/25/2009: Creating Surfaces Arrows
08:09:12.7 5/25/2009: Creating Surfaces GameEXlogo Text
08:09:12.7 5/25/2009: Creating Surfaces Toolbar
08:09:12.7 5/25/2009: Creating Surfaces Backgrounds
08:09:12.9 5/25/2009: Creating Surfaces Toolbar Controls
08:09:12.9 5/25/2009: Creating Surfaces GameEx Logo
08:09:12.9 5/25/2009: Creating Surface Unselected
08:09:12.9 5/25/2009: Creating Surfaces Home & Exit
08:09:12.9 5/25/2009: Creating Surfaces Snaps
08:09:12.9 5/25/2009: Creating Surfaces Menu and List Bars
08:09:13.0 5/25/2009: Creating Fonts
08:09:13.0 5/25/2009: Creating Game Font
08:09:13.5 5/25/2009: Creating Game Font Faded
08:09:14.5 5/25/2009: Creating Title Font
08:09:14.5 5/25/2009: Restoring Title Font From Cache
08:09:14.5 5/25/2009: Creating Menu Font
08:09:14.6 5/25/2009: Creating Font Black
08:09:14.7 5/25/2009: Creating Font Black Small
08:09:14.8 5/25/2009: Fonts Created Succesfully
08:09:14.8 5/25/2009: 108mb video memory left available
08:09:14.8 5/25/2009: Creating instance of global keyboard hook
08:09:18.8 5/25/2009: Attempting to load game list
08:09:19.2 5/25/2009: Text/Language: English
08:09:19.2 5/25/2009: Applying Language/Text
08:09:19.2 5/25/2009: Initialising Bass Audio Library
08:09:19.3 5/25/2009: MAME CMD options: -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow
08:09:19.3 5/25/2009: Loading last used Game List
08:09:19.3 5/25/2009: Setting Music Volume
08:09:19.3 5/25/2009: Creating DirectSound Device
08:09:19.3 5/25/2009: Trying: Primary Sound Driver
08:09:19.3 5/25/2009: Loading Sound Files
08:09:19.3 5/25/2009: DirectSound Device Created Successfully
08:09:19.3 5/25/2009: Creating ICONS
08:09:19.3 5/25/2009: Recreating ICONS
08:09:19.5 5/25/2009: Initialising DirectInput for Gamepad support
08:09:19.7 5/25/2009: Unable to create a joystick device
08:09:19.7 5/25/2009: Initialising DirectInput for Keyboard support
08:09:19.8 5/25/2009: Initializing MCE Remote
08:09:19.8 5/25/2009: Playing intro sound file
08:09:19.8 5/25/2009: Initialization OK! Starting GameEx!
08:09:19.9 5/25/2009: Testing Main Loop Once: Processing Frame
08:09:20.1 5/25/2009: Testing Main Loop Once: Main Loop ran successfully
08:09:47.8 5/25/2009: Running: cmd.exe /c C: C:\mame\mame.exe 1942b -rompath C:\mame\roms -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -bezel -artwork_directory artworkgameex
08:09:55.3 5/25/2009: Exiting GameEx!
08:09:55.3 5/25/2009: Saving Settings
08:09:56.9 5/25/2009: Disposing Plugins
08:09:56.9 5/25/2009: Closing database connection
08:09:56.9 5/25/2009: Checking for applications to Launch On Exit
help please
thanks
figured this one out. after reading the last game section. and deleted the skip disclaimer thing.
thanks anyways
