Hi all, Im really having trouble setting up with a working spectrum emulator.
I use my PC as normal and switch VGA cable to my arcade machine when I run Gameex so Ideally I want to be able to use an emu that sticks with a 640 x 480 res. when gameex launches it.
I know there is the bigger issue with configuring controls for each game through the arcade controls as well but i dont think that is as easy to sort!
Would really appreciate some guidance with which emu to use and an example config would be great! thank you all.
Probably the easiest way to handle Spectrum games would be to use MESS. There are several configs for MESS in the stickied thread at the top of the forums. The config for spectrum would be exactly the same, with just the spectrum info substituted in the command line. Sorry, that its kinda vague, but its been a while since I've set up MESS. I need to set it up on my new machine anyway, so I'll post later this evening after I get home and play with it. There are several places to get the info on the command line switches. Just google for it and I'll try to help later if I can. Good Luck! :)
-Matt
