-= Off Topic =-
This is probably a simple question, but what video plugin do people use for Project 64? I was using the Rice plugin, but it was causing lags on Mario Kart when the small video screen appears (in the first level and in wario stadium). I tried the Jobo plugin, but it's SLOOOOOOOW.
I was just watching a video on youtube where someone apparently disabled the mini video screen somehow. If anyone knows how to do this or can suggest a better plugin, that would be MUCH appreciated! For reference, I'm using v1.6.
-= Off Topic =-
I use the Rice plugin or Jabos I believe. Anywho I use 1.7 as it is much better and has updated plugins. I am a beta tester and the last official release is 1.7.49 and if you come across a .55 is a hex edited 49 build with a trojan. Stay away.
I was wondering about that. I grabbed a version of 1.7 off emule a while back to see if there was anything worth donating to get and it tripped my virus scanner. I decided that it wasn't worth it and have been using 1.6 ever since. Maybe I'll take another look at 1.7. It might even be worth the donation if things play smoother!
I second the 1.7 idea... Paid to beta test (even though the updates just haven't been hitting as hard lately), and I also use texture packs for Mario Kart and it works awesome for me. :)
Just curious. I ran across a usable version of 1.7 to play around with the other day. It seems to work well, but it has a "Emulation Started <Time>" displayed across the bottom of the screen. Is there a way to turn it off? It's not a huge thing, but 1.6 doesn't do that.
