Hi there, i am new here and i would like to say what a GREAT program this is.
I am soo pleased i found it and i have already donated for the registered version :D
I need so help if anyone knows.
I have setup GOM Player to be my default external video player and its working fine.
How ever dose anyone know a way to start it in full screen mode with out having to press ctrl + Enter all the time
(ctrl + Enter is the default keys for full screen in GOM Player)
As i am new to this i am unsure so any help would be GREAT.
When using the advanced configuration goto where you setup your emulators. In the emulator config look for "keys to send" and "Wait to send keys" the text may read diffrently but it will be close enough.. Anyway press the ? symbol and it will give you a refrence site for key code. Once you find your key codes for CTRL+ENTER put them in the keys to send box. In the Wait area be sure to specify enough time for the program to load before truing to send it into full screen mode.
i dont have the video player set as a emulator tho.
i have it set in MultiMedia/HTPC and in there under External Video CMD: C:\Program Files\GRETECH\GomPlayer\GOM.exe
I have all my game emulators site to open full screen and works now problem but because the video setting is not set as a emulator there is no opition to setup a key to send
i was hoping maybe there was somethink i could have added in the above command line or edit a config file to do it
I will look into GOMplayer.
3 hour turn around time Brian... Your getting slow! :o
Must be my old age. :)
Or becase I ate too muck BBQ steak last night.. Porterhouses were on sale.
Now I am at work and just got done eating lunch and man I am moving slow.
Unzip the Archive I have attached and run the Gomwatcher.exe
Then run some videos through gameex and tell me if it works.
Yes m8 thats dose work.
:( Rub it in!
LOL. Sorry Brian! Didn't mean to steal your thunder! :P
Not at all man.. I looked for that setting before I even bothered with the script. I wish I saw it. Would have saved me some time.
Frequency +1 Brian 0
Next time check with me first! LOL. :lol:
