Hi!
I'm playing VisualPinball through Gameex and it works well
My only problem is that the score window is just a little too high on my screen, i mean i don't see the top of the window score
So everytime i play a table, i move down the score window with my mouse to be able to see it fully
I'm doing this everytime i play a table because VisualPinball don't seems to memorize the position of the window when i quit a table
How can i fix his position??
Do i have to edit the .vpt table???
This could be a resolution problem in VP.
Do you have the same issue out side GameEx?
I can only suggest to check this.
Open the VPinball.exe
At the top, click on preferences.
In the list, click on video options.
Here make sure that you screens resolution is set correctly.
Then load the game from here and see if moving the score window will save after exit.
I know some of the pinball games have a default where this screen is.
I am not sure if you can change them with out messing up the table. If you try, Make a back up of the table first and use that to mess around with.
Good luck.
