Hi guys. I'm trying to set daphne up in GameEX but i'm really struggling. I've got all the games working through daphneloader but not through gameex. I've tried following that pdf guide from JustinCase but it doesn't work.
What do I do? I notice in the gameex config menu for daphne there are Game ROM, Game Name, Game Options fields for each game. What do I put in these?
Any help here much appreciated.
Also, when I double click DaphneLoader I get an error message saying "Cannot Update Control File! Unable to update control file due to the following error: Key decryption failed."
Thanks again guys.
Thanks again guys.
Read This thread:
http://www.gameex.info/forums/index.php?s=...ost&p=22960
Hi Brian. Thanks for this, but i've managed to set it all up. Just got a few questions if thats ok? PM me if u like:
1. why do some games have different rom names eg cobra and cobraab? Are they the same game? whi9ch is better?
2. what is primary and secondary key input? is that like 1 and 2 player? i'm really confused about how to set up my controller (keyboard encoder)
ta x
ta x
Also, how do you make your key input changes stick? I've been messing about with them seeing if I can get my head round it, but whenever I change the keys input, as soon as I close daphneloader, it reverts back to type.
HELP x :o
p.s. how do I set up buttons for 1 and 2 players?
We can keep the conversation in the thread. This is so everyone can benefit incase this come up again.
You can map the buttons per game by using daphne loader and choosing the confguration tab. If it is not saving your config perhaps your files are set to "read only" If you are using a keyboard encoder like an IPAC the buttons are simply key presses.
The next solution Id suggest are using auto hot key to remap the IPAC keys to daphne defaults. We can help with this as long as you provide us with your current IPAC configuration and daphnes default keys.
The laserdisc image is actually the game. This is the same for all versions. The ROM tells the system what scenes to play in what order. The frames are defined from the frame file.
So the diffrences in your cobra command roms are diffrent scenes play at diffrent points.
Hope this helps
Hope this helps
Hi Brian. Thanks for helping me with this.
Ok.... I can't use auto hot key because I have 4 other emulators all set to use the same set of keys. If I remapped my ipac for daphne's defaults, I would probably be creating more problems for myself.
Regarding the different rom commands - i would have thought cobra was the main rom name for cobra command, however gameex has cobraab as the ROM. Is that right? It loads up fine btw.
To save config files, can I just change them and then hit the X to close down daphneloader? Or do I need to File / Exit?
Also, if I want to set up keys for 1 and 2 players, how is that done? Is Primary player 1 and secondary player 2? It's very confusing because you have Coin 1 and Coin 2 on both primary and secondary, same with Start 1 and 2.
Thanks hun
I've noticed a file called dapinput. It has all the keys (up, down, coin 1 etc) and then numbers next to each field. This must be the config for the keys but I don't understand all the numbers and how to change them to the keys I want.
Keep in mind this as well. There are some times mulitple version of these laser disc floating around. Dragon's Lair has muliple rips from DVD, HD DVD, Laserdiscs, re-encoded versions are more so don't let that throw you off too much.
So where are you at with this right now, what are you still trying to get working with it?
The key input config thingy. I don't understand it. Whenever I remap the keys through the Configure option, it never saves it and reverts back to default.
Also, do I map keys for Player 2? Or does player 2 use the same keys as Player 1? Never played laser disk games so don't know.
Thanks.
So then post your current IPAC keys config. Then open daphne and post its defaults and Ill make a config for you.
Hi Brian. I have managed to change the keys in DaphneLoader and it appears (when looking at the input field) to have changed permanently. However, when playing the game, the keys are the same as the old default.
Is it because I have changed them in DaphneLoader but I am playing the games through Daphne?
My keys for your config are:
Primary Key:
Up - Up arrow
Left - left arrow
Right - right arrow
Down - down arrow
Start 1 - 1
Start 2 - 2
Button 1 - Q
Button 2 - E
Button 3 - R
Coin 1 - 3
Coin 2 - 4
Quit - escape
Pause - P
Secondary Key:
Up - W
Left - A
Right - D
Down - S
Start 1 - 1
Start 2 - 2
Button 1 - Z
Button 2 - X
Button 3 - C
Coin 1 - 3
Coin 2 - 4
Quit - escape
Pause - P
As Clair said earlier, there is a file called dapinputi.ini in the daphne folder that has the default mappings in it. There is also a file called keylist.txt that shows what codes to use for which keys. I couldn't remap my keys through DaphneLoader, so I just changed the codes myself. I don't see any codes for gamepads though.
You could just make a script to setup your xpadder profiles, and then call Daphne yourself from the script, apparently you can change the name of the Daphne.exe, if you change it in the GameEx.ini yourself. That's what I'm doing with my "Marquee Magician" script to display graphics on the second monitor.
I was going to make a loader a while back, but then had some other problems that needed addressing first. I think I can get back to this now. Thanks for the info!
Brian I was just wondering if you'd got round to doing that config. As mentioned in my previous post, I can set the keys in DaphneLoader but this doesn't work when gameex launches Daphne.
Also, what do I put as my rom names in setting up in gameex? There are lots of different names for each game e.g. cobra - cobraab, astron - astronp, rb - roadblaster
Is this the Daphne config you need working? If so this is what I need.
I also need your current ipac config.
So currently what I need are. Please edit the table below once you reply.
From the Left the keys are what the IPAC is currently. The Right is what daphne wants the keys to be.
Player 1 Defaults
Current Default------------Daphne Default
Up= Up Arrow ---------Up= Up Arrow
Left=--------------------Left=
Down=-----------------Down=
Right=------------------Right=
Button1=---------------Button1=
Button2=---------------Button2=
Button3=Left Shift-----Button3=Y
Coin1=-----------------Coin1=
Coin2=-----------------Coin2=
Start1=-----------------Start1=
Start2=----------------Start2=
Player 2 Defaults
Not quite sure what you mean Brian. I listed all the buttons in a previous post is that what you mean? :blink:
you gave me one set of buttons. I need to know what the current key is followed by the key it needs to be mapped to.
If by default button1 for daphne is "x" and your current button 1 is "j" then I need to remap J to X.
Get it?
Use the above table to define your existing controls and the defaults for daphne.
I really cant explain myself any better. I hope this helps.
Player 1 Defaults
Left=Left Arrow --------------------Left= Left Arrow
Down= Down Arrow -----------------Down= Down Arrow
Right= Right Arrow ------------------Right= Right Arrow
Button1= Q---------------Button1=space
Button2= E---------------Button2=left alt
Button3=R -----Button3=left shift
Coin1=3 -----------------Coin1=5
Coin2=4 -----------------Coin2=6
Start1=1-----------------Start1=1
Start2=2----------------Start2=2
Player 2 Defaults
Up=W ---------Up= [8]
Left=A --------------------Left=[4]
Down=S -----------------Down=[2]
Right=D ------------------Right=[6]
Button1=Z ---------------Button1=left ctrl
Button2=X ---------------Button2=
Button3=C -----Button3=
Button 1 and 3 for secondary key are blank. Also, I don't understand that coin 1 coin 2 start 1 start 2. Is coin 1 - coin for player 1, start 2 - start for player 2? etc
I don't have that keylist.txt file :(
Also, what do I put as my rom names in setting up in gameex? There are lots of different names for each game e.g. cobra / cobraab, astron / astronp, rb / roadblaster etc.
Keylist.txt
BACKSPACE = 8
TAB = 9
CLEAR = 12
RETURN = 13
PAUSE = 19
ESCAPE = 27
SPACE = 32
EXCLAIM = 33
QUOTEDBL = 34
HASH = 35
DOLLAR = 36
AMPERSAND = 38
QUOTE = 39
LEFTPAREN = 40
RIGHTPAREN = 41
ASTERISK = 42
PLUS = 43
COMMA = 44
MINUS = 45
PERIOD = 46
SLASH = 47
0 = 48
1 = 49
2 = 50
3 = 51
4 = 52
5 = 53
6 = 54
7 = 55
8 = 56
9 = 57
COLON = 58
SEMICOLON = 59
LESS = 60
EQUALS = 61
GREATER = 62
QUESTION = 63
AT = 64
LEFTBRACKET = 91
BACKSLASH = 92
RIGHTBRACKET = 93
CARET = 94
UNDERSCORE = 95
BACKQUOTE = 96
a = 97
b = 98
c = 99
d = 100
e = 101
f = 102
g = 103
h = 104
i = 105
j = 106
k = 107
l = 108
m = 109
n = 110
o = 111
p = 112
q = 113
r = 114
s = 115
t = 116
u = 117
v = 118
w = 119
x = 120
y = 121
z = 122
DELETE = 127
KP0 = 256
KP1 = 257
KP2 = 258
KP3 = 259
KP4 = 260
KP5 = 261
KP6 = 262
KP7 = 263
KP8 = 264
KP9 = 265
KP_PERIOD = 266
KP_DIVIDE = 267
KP_MULTIPLY = 268
KP_MINUS = 269
KP_PLUS = 270
KP_ENTER = 271
KP_EQUALS = 272
UP = 273
DOWN = 274
RIGHT = 275
LEFT = 276
INSERT = 277
HOME = 278
END = 279
PAGEUP = 280
PAGEDOWN = 281
F1 = 282
F2 = 283
F3 = 284
F4 = 285
F5 = 286
F6 = 287
F7 = 288
F8 = 289
F9 = 290
F10 = 291
F11 = 292
F12 = 293
F13 = 294
F14 = 295
F15 = 296
NUMLOCK = 300
CAPSLOCK = 301
SCROLLOCK = 302
RSHIFT = 303
LSHIFT = 304
RCTRL = 305
LCTRL = 306
RALT = 307
LALT = 308
RMETA = 309
LMETA = 310
LSUPER = 311 /* Left "Windows" key */
RSUPER = 312 /* Right "Windows" key */
MODE = 313 /* "Alt Gr" key */
COMPOSE = 314 /* Multi-key compose key */
/* Miscellaneous function keys */
HELP = 315
PRINT = 316
SYSREQ = 317
BREAK = 318
MENU = 319
POWER = 320 /* Power Macintosh power key */
EURO = 321 /* Some european keyboards */
My Daphne setup (I'm not saying it's the best, but it works, well maybe not all of them... LOL)
Enabled_1 =True
ROMName_1 =mach3
GameName_1 =Mach 3
GameOptions_1 =-framefile C:\Emulators\Daphne\vldp\mach3\mach3.txt
Enabled_2=True
ROMName_2 =ace
GameName_2 =Space Ace
GameOptions_2 =-framefile C:\Emulators\Daphne\vldp\ace\ace.txt
Enabled_3=True
ROMName_3 =astron
GameName_3 =Astron Belt
GameOptions_3 =-framefile C:\Emulators\Daphne\vldp\astron\astron.txt
Enabled_4=True
ROMName_4 =badlands
GameName_4 =Badlands
GameOptions_4 =-framefile C:\Emulators\Daphne\vldp\badlands\badlands.txt
Enabled_5=True
ROMName_5 =cobraab
GameName_5 =Cobra Command
GameOptions_5 =-framefile C:\Emulators\Daphne\vldp\cobra\cobra.txt
Enabled_6=True
ROMName_6=esh
GameName_6=Esh's Aurunmilla
GameOptions_6=-framefile C:\Emulators\Daphne\vldp\esh\esh.txt
Enabled_7=True
ROMName_7=bega
GameName_7=Bega's Battle
GameOptions_7=-framefile C:\Emulators\Daphne\vldp\bega\bega.txt
Enabled_8=True
ROMName_8=galaxy
GameName_8=Galaxy Ranger
GameOptions_8=-framefile C:\Emulators\Daphne\vldp\galaxyr\galaxyr.txt
Enabled_9=True
ROMName_9=roadblaster
GameName_9=Road Blaster
GameOptions_9=-framefile C:\Emulators\Daphne\vldp\rb\rb.txt
Enabled_10=True
ROMName_10=sdq
GameName_10=Super Don Quix-ote
GameOptions_10=-framefile C:\Emulators\Daphne\vldp\sdq\sdq.txt
Enabled_11=True
ROMName_11=uvt
GameName_11=Us vs. Them
GameOptions_11=-framefile C:\Emulators\Daphne\vldp\uvt\uvt.txt
Enabled_12=True
ROMName_12=gpworld
GameName_12=Grand Prix World
GameOptions_12=-framefile C:\Emulators\Daphne\vldp\gpworld\gpworld.txt
GameName_23=
Enabled_13=True
ROMName_13=interstellar
GameName_13=Interstellar
GameOptions_13=-framefile C:\Emulators\Daphne\vldp\interstellar\interstellar.txt
Enabled_14=True
ROMName_14=gtg
GameName_14=Goal to Go
GameOptions_14=-framefile C:\Emulators\Daphne\vldp\gtg\gtg.txt
Enabled_15=True
ROMName_15=cliff
GameName_15=Cliff Hanger
GameOptions_15=-framefile C:\Emulators\Daphne\vldp\cliffhanger\cliff.txt
Enabled_16=True
ROMName_16=firefox_alt
GameName_16=Fire Fox
GameOptions_16=-framefile C:\Emulators\Daphne\vldp\firefox\firefox.txt
Enabled_17=True
ROMName_17=lgp
GameName_17=Laser GP
GameOptions_17=-framefile C:\Emulators\Daphne\vldp\lasergp\lasergp.txt
Enabled_18=True
ROMName_18=dle20
GameName_18=Dragons Lair
GameOptions_18=-framefile C:\Emulators\Daphne\vldp\lair\lair.txt
Enabled_19=True
ROMName_19=dle21
GameName_19=Dragon's Lair 2
GameOptions_19=-framefile C:\Emulators\Daphne\vldp\lair2\lair2.txt
Enabled_20=True
ROMName_20=tq
GameName_20=Thayer's Quest
GameOptions_20=-framefile C:\Emulators\Daphne\vldp\tq\tq.txt
Enabled_21=True
ROMName_21=ace2
GameName_21=Space Ace 2
GameOptions_21=-framefile C:\Emulators\Daphne\vldp\ace2\sa91.txt
Brian - How about I make a simple script to build scripts to map keys? Press a key on the keyboard that the game expects, press a second key that you want to use? Good Idea? or just plain silly? Or a tutorial on how to do it. (It's so easy a caveman could do it!)
Keylist.txt
Ya I was thinking the same thing. Kinda a key2key.exe
I invision either building a GUI to prompt for a user to press the key (button) Then record the button pressed to an INI.
Then prompt the user to select the key they need it to be mapped to from a dropdown and write to the INI. (The reason for the dropdown would be because if your using an IPAC you may not have a keyboard connected to press the button you would like it to be.) Upon Finishing it will prompt to name the file. EG.. Daphne.INI
Then you can launch Keytokey.exe daphne.ini and have it load specific configs and you can have as many as you want.
If a Gui isnt created the INI will be made by hand. (not a big deal) However it seems even that maybe hard to understand.
What do you think?
If you think it's worthwhile, I'll work on it (I've got time ;) ) I wouldn't think an ini file would be necessary... Just output the code needed, and move on... Unless your thinking of storing a users preferences for p1b1, etc...
You know what else would be cool, is if it had the default inputs for common emulators...
How about pictures of the emulators original controls, so you can see what buttons you are assigning (as some emulators (SSF?) have...
How crazy do you want to go? Talk to Me!
