I'm new here but have been using Gameex for over a year and ran into an emulator problem with SNES and ZSNES - When I launch the emulator it won't launch the ROM's I've selected in Gameex - The emulator screen just pop's up until I close it or whatever - I've loaded a second install of Gameex with the same result for both SNES and ZSNES - The thing was this was working before I tried to change the emulator to SNES@!? I'm on XP with the latest .net etc... Here is my config.ini file for the emulator 9 & 10 that I am using for ZSNES - Thanks for any help hopefully this is something easy that I'm missing!
EMU_9LastFolderWrite=11/23/2008 11:37:44 PM
EMU_9LastRomFilter=*.*
EMU_9_ROMFilter=*.*
EMU_9_RomsInFolders=True
EMU_9_RomPath=D:\zsnes\rom
EMU_9_WorkingPath=D:\SNES
EMU_9_MapKeys=True
EMU_9_ReplaceDash=True
EMU_9_ReplaceUnder=True
EMU_9_Capitals=True
EMU_9_RemoveBrackets=True
EMU_9_ShowDesktop=True
EMU_9_Debug=True
EMU_9_Command=snes9x.exe
EMU_9_configFile=Test
EMU_9_PlayInScreenSaver=True
Version=8.96
and
EMU_10LastFolderWrite=11/24/2008 9:56:12 PM
EMU_10LastRomFilter=*.*
EMU_10_DBCACHEModified=11/12/2007 1:55:04 AM
EMU_10_LastNumGames=11414
EMU_10_DBCACHELastName=[Console] Nintendo SNES
EMU_2_DATABASE=[Console] Nintendo SNES
EMU_10_RomsInFolders=False
EMU_10_RomPath=D:\zsnes\rom
EMU_10_WorkingPath=D:\zsnes
EMU_10_MapKeys=True
EMU_10_ReplaceDash=True
EMU_10_ReplaceUnder=True
EMU_10_Capitals=False
EMU_10_RemoveBrackets=False
EMU_10_ShowDesktop=False
EMU_10_Debug=True
EMU_10_Command=zsnesw.exe
EMU_10_Database=[Console] Nintendo SNES
EMU_10_GamesIn7Zips=False
EMU_10_ShowMostPlayed=True
EMU_10_RandomMostPlayed=True
You're not passing the rom to the command line.
Snes should be:
snes9x.exe "[ROMPATH]\[ROMFILE]"
ZSNES should be:
zsnesw.exe "[ROMPATH]\[ROMFILE]"
Just make those changes to the command and you should be good to go.
Change the command to
snes9x.exe "[rompath]\[romfile]"
This is a simple fix. The problem is you ARE only launching the emulator.
Example: EMU_9_Command=snes9x.exe
Snes9x.exe is the emulator executable.
To load a game you need to pass the rompath and romfile information
It would look as follows.
snes9x.exe "c:\my snes games\chrono trigger.zip"
The GameEX FE creates a game list from the following config information
Rom Filter(this is files extention) = *.zip (the astrix is a wildcard that means any file name that shares the Zip extion)
Rom path (this is the location of the games) = c:\my snes games\
Gameex treats these as [rompath] and [romfile]
Gameex launches the emulator from the following
Working path (this is where the emu resides) = c:\my snes emu\
Command (The emulator command you want gameex to use)
So the complete command would be
Gameex will lauch it like
"c:\my snes emu\snes9x.exe" "c:\my snes games\chrono trigger.zip"
