ok I just install zsnes on my game ex and its runing find.but the problem is every time I hit the esc button the menu of zsnes show up and fades away back to my game ex menu.is there anyway to fix this problem or any other way to stop it form showing up.I dont know where to calibrate it
Just map the exit key to something like "q" and use an advanced config to exit it. It will no longer show the menu.
Zsnes:
  1. Misc
  2. Misc Keys
  3. Exit
  4. Q or whatever key you want.
GameEx Settings:
  1. Point to Advanced Config ZSNES V6 or create your own.
ZSNES V6 advanced config looks like it's already setup for you to just hit "q" and it will exit.
In the zsnes confg there is an option to disable the GUI.
Edit the config manually and tellit gui=0 or something to that effect.
Thanks for jumpin in Brian! The setting is:
guioff=1
Disable GUI (0 = NO, 1 = Yes)
Found in the GUI section of the zsnesw.cfg file.
Thank you Brian Hoffman & fRequEnCy the Disable GUI really did the trick.I added the 1 to it and now its at fruity loops to the max :lol:
I have my psone,mugen and snes working like coco.Just a few emulator to do and after that I am at 100% ;)
