Hi all, got a really basic knowledge of computers but hey, you never know I might learn something today so here goes.
When trying to start a epsxe game in gameex I get "bios not found" but it is there it just I'm not pointing it to the right place and don't know how to.
I've attached a log of it so if someone would please kindly help me that would be great.log_file.txt
Great front end BTW.
create a sub directory in the epsxe folder and name it bios. then copy your file SCPH1001.BIN in there
Cheers for your help but I already done that. I can play games outside of gameex, just not when using it. Does everything look oK in the log?
you don't need to start daemon tools beforehand. try deleting the entries in "launch before/after" and use the following command:
ePSXe.exe -nogui -loadbin "[RomPath]\[RomFile]"
Thanks a lot mate!! that done the trick.
