Hi, I got my reg key and when i double clicked it Windows said i didn't recognise the file. So I said open with gameEx and now it still doesn't work.
How do I change it so windows knows what type of file it is, or can I manually put the info in the registry?
cheers
cheers
Follow these steps:
1. Right Click on File
2. Select Properties
3. Where it says Open With (where you changed to GameEx) click the Change button
4. If Registry Editor is not found then Click on Browse button
5. Browse to your WINDOWS directory and select regedit.exe and click open
6. Click ok
7. Now double click on file and it will ask you if you want to add to registry and click Yes
Or yes you can just manually put into the registry.
