I have a dual monitor setup, I have one video card with dual outputs, one digital, one analog. The analog output is running to an lcd monitor and the digital output is running from the dvi output on my card to the hdmi on my lcd projection tv using a converter cable. The card itself is a GeForce 7600 GS and the latest downloaded driver for it. The resolution to my tv is not augmented via the driver to size to the tv since sometimes it needs it with different resolutions. It is on a dualview setup vs a clone view setup. The tv is running natively at 1176x664. I am also on windows xp.
I found that when i am watching a video file (ffdshow is my only codec set installed since this is pretty much a clean install except for xp sp3 and all current updates) and i wish to change the volume using my ehome (microsoft media center) remote, it freezes gameex and closes it. The visual and audio experience i get is.
1. Start watching the video file
2. Press the volume up or down (it doesnt matter which)
3. A sound like as if i pressed the ok button on the remote to select something sounds
4. The screen goes black on my secondary monitor (the one which game ex is set to use)
5. I see the volume changing icon on the monitor by itself (the rest of the screen is black) in the far right center of the screen for a brief moment
6. Screen goes black again then game ex closes and gives me the error report.
I have reproduced these steps with different variables (such as trying different video files at different resolutions and aspect ratios. Additionally changing the volume at different places during playback) on my secondary monitor with the same result.
However when using my primary monitor as game ex's video output everything works fine (no errors when i change volume on the remote). I see the volume box appear the right side of the screen appear while the video is still playing and dissapearing after there have been no button presses on the remote after 1/2 to 1 second)
Heres the output of the full error log. I have tried both mce glossy and mce glossy v3 themes.
Additionally i have DirectX 9c installed.
22:31:27.0 9/12/2008: GameEx: Version 9.53: Starting Log
22:31:27.0 9/12/2008: Operating System Platform: Win32NT
22:31:27.0 9/12/2008: Operating System Name: Windows XP
22:31:27.0 9/12/2008: Operating System Version: 5.1.2600
22:31:27.0 9/12/2008: Checking for versions of .net Framework installed
22:31:27.0 9/12/2008: .net Framework 2.0 Installed
22:31:27.1 9/12/2008: Intel® Pentium® D CPU 3.40GHz, 2047MB
22:31:27.1 9/12/2008: 3.4Ghz - 2 Cores or CPU's
22:31:27.1 9/12/2008: Running Randomize()
22:31:27.1 9/12/2008: Loading PlugIns
22:31:27.1 9/12/2008: Checking for applications to Launch On Startup
22:31:27.1 9/12/2008: Running Misc startup tasks
22:31:27.1 9/12/2008: Setting Menu types
22:31:27.1 9/12/2008: Opening Configuration File
22:31:27.1 9/12/2008: Getting Configuration Values
22:31:27.1 9/12/2008: Using Theme: Default - MCE Glossy
22:31:27.1 9/12/2008: Checking for alternate Image Directory for Theme: Default - MCE Glossy
22:31:27.1 9/12/2008: GameEx will display on Secondary Device
22:31:27.1 9/12/2008: Launching HideOS.exe
22:31:27.1 9/12/2008: Initialising Video/MNG DLL's
22:31:27.1 9/12/2008: GameEx will check for media insertion (may affect performance)
22:31:27.1 9/12/2008: Is Media Center running?
22:31:27.1 9/12/2008: Checking/Creating LCD Registry values
22:31:27.1 9/12/2008: Check Media Center Exit/Start Mode
22:31:27.1 9/12/2008: Media Center Mode 2
22:31:27.1 9/12/2008: Video previews on. Warning: Only recommended on modern systems
22:31:27.1 9/12/2008: Snap Delay set to: 2
22:31:27.1 9/12/2008: Get other settings
22:31:27.2 9/12/2008: Set: Find emulator artwork on best match basis
22:31:27.2 9/12/2008: Start work for Form
22:31:27.2 9/12/2008: Getting Original Screen Size
22:31:27.2 9/12/2008: Opening Database Connection
22:31:27.4 9/12/2008: Initializing Component
22:31:27.4 9/12/2008: Retrieving resolution setting
22:31:27.4 9/12/2008: MAME Path is: D:\MAME
22:31:27.4 9/12/2008: MAME EXE file is: mameuifx32.exe
22:31:27.4 9/12/2008: ROM Path is: D:\MAME\roms
22:31:27.4 9/12/2008: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
22:31:27.4 9/12/2008: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
22:31:27.4 9/12/2008: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
22:31:27.4 9/12/2008: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
22:31:27.4 9/12/2008: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
22:31:27.4 9/12/2008: Loading Controls.ini map file
22:31:27.4 9/12/2008: Snap Path is: D:\MAME\snap
22:31:27.4 9/12/2008: AVI Snap Path: Not Found
22:31:27.4 9/12/2008: Flyer Path is: D:\MAME\flyers
22:31:27.4 9/12/2008: Cabinet Path is: D:\MAME\cabinets
22:31:27.4 9/12/2008: Title Path is: D:\MAME\titles
22:31:27.4 9/12/2008: PCB Path: Not Found
22:31:27.5 9/12/2008: Artwork Preview Path: Not Found
22:31:27.5 9/12/2008: Panel Path is: D:\MAME\cpanel
22:31:27.5 9/12/2008: Manual Path: Not Found
22:31:27.5 9/12/2008: Icon Path is: D:\MAME\icons
22:31:27.5 9/12/2008: Marquee Path is: D:\MAME\marquees
22:31:27.5 9/12/2008: Loading Custom Emulators
22:31:27.5 9/12/2008: Loading Emulator 1: Nintendo NES Games
22:31:27.5 9/12/2008: Loading Emulator 2: Nintendo SNES games
22:31:27.7 9/12/2008: Using 2D Animations
22:31:27.7 9/12/2008: Using General Font: Trebuchet MS
22:31:27.7 9/12/2008: Using Title Font: Trebuchet MS
22:31:27.7 9/12/2008: Attempting to load game list
22:31:27.8 9/12/2008: Initialising DirectDraw
22:31:30.1 9/12/2008: Creating DirectDraw Device: Secondary Device
22:31:30.1 9/12/2008: Using Device: NVIDIA GeForce 7600 GS
22:31:30.3 9/12/2008: 497mb video memory available
22:31:30.7 9/12/2008: Setting Resolution to 1176x664 32 bit color
22:31:30.7 9/12/2008: Creating DirectDraw Surfaces
22:31:30.7 9/12/2008: Creating Primary Surface - Full Screen Mode
22:31:30.8 9/12/2008: Creating Back Buffer
22:31:30.8 9/12/2008: Loading graphic Surfaces
22:31:30.8 9/12/2008: Display is running at: 1176x664 32bit color, 60hz
22:31:30.9 9/12/2008: Creating Surfaces Flags
22:31:30.9 9/12/2008: Creating Surfaces Misc and Dialogs
22:31:30.9 9/12/2008: Creating Surfaces Volume
22:31:30.9 9/12/2008: Creating Surfaces Arrows
22:31:30.9 9/12/2008: Creating Surfaces GameEXlogo Text
22:31:30.9 9/12/2008: Creating Surfaces Toolbar
22:31:30.9 9/12/2008: Creating Surfaces Backgrounds
22:31:33.2 9/12/2008: Creating Surfaces Toolbar Controls
22:31:33.2 9/12/2008: Creating Surfaces GameEx Logo
22:31:33.2 9/12/2008: Creating Surface Unselected
22:31:33.2 9/12/2008: Creating Surfaces Home & Exit
22:31:33.2 9/12/2008: Creating Surfaces Snaps
22:31:33.2 9/12/2008: Creating Surfaces Menu and List Bars
22:31:33.3 9/12/2008: Creating Fonts
22:31:33.3 9/12/2008: Creating Game Font
22:31:33.3 9/12/2008: Creating Game Font Faded
22:31:33.4 9/12/2008: Creating Title Font
22:31:34.7 9/12/2008: Creating Menu Font
22:31:34.9 9/12/2008: Creating Font Black
22:31:35.0 9/12/2008: Creating Font Black Small
22:31:35.1 9/12/2008: Fonts Created Succesfully
22:31:35.1 9/12/2008: 430mb video memory left available
22:31:35.1 9/12/2008: Creating instance of global keyboard hook
22:31:58.1 9/12/2008: Text/Language: English
22:31:58.1 9/12/2008: Applying Language/Text
22:31:58.2 9/12/2008: Initialising Bass Audio Library
22:31:58.3 9/12/2008: MAME CMD options: -nowindow -joy -skip_gameinfo -mouse
22:31:58.3 9/12/2008: Loading last used Game List
22:31:58.3 9/12/2008: Setting Music Volume
22:31:58.3 9/12/2008: Cannot Load Play List. Check Path and filename
22:31:58.3 9/12/2008: Creating DirectSound Device
22:31:58.3 9/12/2008: Trying: Primary Sound Driver
22:31:58.3 9/12/2008: Loading Sound Files
22:31:58.3 9/12/2008: DirectSound Device Created Successfully
22:31:58.3 9/12/2008: Creating ICONS
22:31:58.4 9/12/2008: Recreating ICONS
22:31:58.5 9/12/2008: Initialising DirectInput for Gamepad support
22:31:58.6 9/12/2008: Unable to create a joystick device
22:31:58.6 9/12/2008: Initializing MCE Remote
22:31:58.6 9/12/2008: Playing intro sound file
22:31:58.6 9/12/2008: Initialization OK! Starting GameEx!
22:31:58.6 9/12/2008: Testing Main Loop Once: Processing Frame
22:31:59.1 9/12/2008: Testing Main Loop Once: Main Loop ran successfully
22:32:39.1 9/12/2008: Playing Video: E:\Movies\The Office\The.Office.S04E14.HDTV.XviD-xor [btarena.org].avi
22:32:44.2 9/12/2008: Error in the application.
22:32:44.3 9/12/2008: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags, DrawEffects bltEffects)
at q.a(Rectangle A_0, Surface A_1, Rectangle A_2, DrawFlags A_3, DrawEffects A_4)
at q.b(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3)
at q.a(Boolean A_0, Boolean A_1, String A_2, String A_3, Boolean A_4)
22:32:47.1 9/12/2008: 21 Consecutive Exceptions Occured
22:32:47.1 9/12/2008: Error in the application.
22:32:47.1 9/12/2008: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
at q.am()
22:32:47.1 9/12/2008: Trying reinitialising the display after sleeping for 4 seconds
22:32:47.1 9/12/2008: Exception count will be dropped to 15
22:32:51.7 9/12/2008: --**--
22:32:51.7 9/12/2008: 21 Consecutive Exceptions Occured: Exiting
22:32:51.7 9/12/2008: Closing database connection
22:32:51.7 9/12/2008: First Exception:
22:32:51.7 9/12/2008: Error in the application.
22:32:51.7 9/12/2008: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
22:32:51.7 9/12/2008: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags, DrawEffects bltEffects)
22:32:51.7 9/12/2008: at q.a(Rectangle A_0, Surface A_1, Rectangle A_2, DrawFlags A_3, DrawEffects A_4)
22:32:51.7 9/12/2008: at q.b(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3)
22:32:51.7 9/12/2008: at q.am()
22:32:51.7 9/12/2008: It was detected you experienced a DirectX error.
22:32:51.7 9/12/2008: Please note the following for possible solutions to your problem:
22:32:51.7 9/12/2008: 1. Ensure you have the latest version of DirectX installed.
22:32:51.7 9/12/2008: 2. Ensure you have the latest Manufacturer provided video card drivers.
22:32:51.7 9/12/2008: NOTE: Windows/Microsoft Update does not contain the latest.
22:32:51.7 9/12/2008: NOTE: Manufacturer normally means ATI, NVidia, or Intel. Not the brand.
22:32:51.7 9/12/2008: www.ati.com www.nvidia.com
22:32:51.7 9/12/2008: 3. If you do not have a modern video card try the following. 1. Turn off advanced Graphics. 2. Try a lower resolution. 3. Try turning on and using 16-bit colour
22:32:51.7 9/12/2008: 4. Ensure any required video codecs are installed.
22:32:51.7 9/12/2008: 5. Try a different theme, or try running the theme at the resolution it was designed for
22:32:51.7 9/12/2008: 6. Try the latest version of GameEx. GameEx is updated all the time.
22:32:51.7 9/12/2008: 7. If you performed an auto update to this version. Try performing a manual download and install.
22:32:51.7 9/12/2008: Last Exception:
22:32:51.7 9/12/2008: Object reference not set to an instance of an object.
22:32:51.7 9/12/2008: at q.cg()
on a side note i also have noticed that when selecting any of my movies, that the preview of the movie is upside down but the actual play of the movie is right side up. However when i check the flip video checkbox (ffdshowconfig->miscellaneous->flip video->unchecked) the inverse happens (the preview is normal but the actual playback is upside down). Just thought i should mention this but to me it may not be a priority above the other bug ;) (*edit - figured out that the side note problem probably lies in the codec itself, would like to see support for VFW though but its just a suggestion. You guys prolly got your hands full so I'll leave it at that)
Thanks guys, game ex is an awesome tool and I appreciate all the hard work put into it :D
BTW, just noticed that the below information in my signature is not acurate anymore. Still lookin for a way to get rid of it.
