Those and control keys like control, shift, alt, enter, tab, windows key, etc. You have 26 number keys plus some symbol keys and space bar. I would avoid using others unless you have to. That should be plenty to configure the vast majority of things unless you want 4 player N64 or something...but that wouldn't work with an xarcade anyway!
I can play n64 games using my IPAC,,, But I dont have any sensivity on the analog obviously.. So its either all the way or nothing.. Most games play ok... Others not so much.
I am also taking it that x-arcade is only a 4 way joystick too? When I play Metal Slug and point to the corner it does not seem to fire at an angle but when I roll it to the corner it does...
