Hello,
I try to create a file for my bat Roma zinc, affin power since the launch gameex. I placed the order
c: \ emulator \ zinc \ zinc.exe 10 (10 for former street fighter 2), save my file giving the extension. bat and placing it at the root of my case is c: \ emulator \ zinc \ but if that does not launch the game I tien has clarified my question Roma and bios are in my file Roma (c: \ emulator \ zinc \ Roma).
Can you remember how ... : D
Thanks to all
Thank you very much but it's true that I would have loved to understand how to do this myself. I know it is possible to use zincfe for more simplicity, but this simplicity does not work with gameex.
someone would explain how to install zinc as well as additional files and follow the approach has to create a file bat valid.
Thanks to you
Thanks to you
Hooray for funky online translations... :P (italian?)
Sorry mate, I'm not a hundred percent sure what you are trying to achieve there but if you downloaded brians batch files you could click on them with the right mouse key and hit edit... then you see what is in there.. basically just the assigned number that zinc uses to launch the games. anyway if you are using gameex you normally wouldn't make use of these bats since gameex has all the necessary zinc commands to make your games launch... the best procedure would be to use zincfe first and see if your games are working (set up controls and everything) if zincfe can launch the game then enable zinc in gameex setup and see if it works for you. sometimes zinc is quite nasty to set up. e.g. i had to disable bluetooth to make it work ( because of hid bluetooth gamecontroller that crashes zinc)
another good hint probabaly is to copy zinc in the mame directory and then point it to the roms. for me zinc had to have the roms in a subfolder under the zinc dir. i couldn't have a zinc folder and a x:\mame\roms folder to access the roms so i just copied the zinc exe and zincfe in x:\mame (dunno why but that made it work)
anyway,
good luck
