I have deleted/filtered Simpsons (parent rom) from my games list. For some reason it doesnt work but one of the clones do, and so I have added it to the 'DO NOT FILTER' field, yet it does not appear.
In fact, it appeared once and then disappeared and I dont know why.
Any ideas?
Any ideas?
I've just realised, when I hit updaye list, the game I have listed in field 'do not filter' appears, but as soon as I exit GameEX and go back in, it's disappeared.
Any ideas?
Any ideas?
I thought this was a bug fixed in a recent release. Are you running the latest version?
I am running the latest version yes. After I hit 'update list' the games appear, but when I hit backspace or move around in the menu, it seems to reset itself and the games disappear.
Could it be that you have the rom in the filter list as well as the do not exclude list? The filter list will override.
No. I have not deleted any clones because I enabled (no clones) in the advanced config.
Could it be that enabling (no clones, do not allow imperfect games) will affect this? It states next to the 'Do not filter' field that this overrides absolutely everything and so I assumed not.
I just don't understand why it appears after the list updates but then disappears.
Any help on this would be much appreciated.
