Just in case anyone missed it
SSF has been updated, not sure if this helps with compat. Does not help with the full-screen switching flicker in Vista though :(
http://www7a.biglobe.ne.jp/~phantasy/ssf/index.html
If anyone is running this is Vista and has no problems with the auto fullscreen switch when run - please let me know what you did?
Drives me nuts.. :(
I had SSF running and now some how it does not work anymore (I get the report the error message) any ideas to get this back working?
delete ssf.ini. set the options again :(
Also - i dont use a bios. on program 3 tab, tick 'no bios' to be able to run games from any region. Slight downside (so im told) is that some games wont work. I have 332 and they all work fine with no bios.
No - still no joy :-(
It works fine on one PC but not the PC in my cab (but as I said it worked fine - once)
it sounds like some kind of corruption...?
unrar ssf to a clean directory and run from there - see if that makes a difference?
Failing that.... Does SSF open up without starting a game?
oh... Are you trying a new game image? ie. have you got a game image mounted (daemon tools etc) and ssf auto starting it? Sometimes a Iso can not mount correctly and will cause ssf to freeze or die! Try with a game you are 100% sure worked.
Tried a clean dir - still no joy
tried with nothin in deamon tools drive - still no joy
tried copying the exact same folder to a diff PC work fine - wired or what
When I click the SSF.exe I get a pause then then microsoft errror message.
Direct x / driver issue perhaps?
Brian has a point. Go to the microsoft site and download the direct x 9a setup. You never know? You can install it over ver C etc. I use vista and needed it to run nuldc.
