Im trying to build my own arcade cabinet but I dont have much money, is there any way to spend less than $500 on building the cabinet?
Of course.... Goto Craigs list and keep an eye out for FREE/ Very inexpensive arcades.
Get an IPAC 50 dollars
Get some happ joysticks... You cab may include some... In that case just some buttons.
Get some Wire and connect your IPAC
Goto the nearest thrift store and pick up a TV for 50 bucks or less... Put it in the cab
Get a 40 dollar geforce card with TV out.
Throw in your PC.. If you dont have one for it then you have to buy that.
Obvoiulsy as this is the heart of the machince.. The cheaper you get the less games you will be able to play.
Some games are quite cpu intensive...
Happy hunting
