hia all
can any one help me out with the controls in epsxe1.7 this is the 1st time ive had it setup and running well
i have setup all my controls but when i use butt 3 the close menu pops up or it stop my psx game
the menu is the one where you left click at the top left of a window and it lets you move, size, min, and maximize an close a window
plus im having some probs with the setup controls in sega model 2 emul
it will not let me setup the accelerate or brake. they are set to analog joy (null) (inv)
im running a jamma 3but cab with ipac and an arcadevga pc2.4gig
hope some one can help
thanx carl.
hia all
thanx carl.
Connect a keyboard to your IPACS and redifine your game pad keys to ones that dont bring up menus etc... So if button 3 is F and thats bringing up the file menu. Make the key you have assigned to button 3 H or something.
Then use autohotkey to map F::H so when you press button 3 it sends H which controls the game and not F that brings up the menu.
Save the script and make an EXE of it (compile) Then lauch that program in the launch before section of the emu. Then in lauch after kill the AHK process so it doesnt break other emus.
hi brian thanx for the fast reply
wow that sounds complicated bit of a noob when it comes to mappin keys an compiling exe and ahk process ?
is there a tut on the forum i can follow like im a 3 year old lol
No here really. But if you tell me what your keys are I can make one up real quick.
I need your directionals and buttons for both players.
Also you said you have a 3 button cab? That will make MOST games un playable. Unless I understood you incorrectly.
thanx brian that be brill m8 if you can do that
is there any easy way of finding out the keys use on my cab!
yes 3 butts im going to add more soon. not 100% if im going to get a new 6butt cab
or if i will stick with the one i have an add butts an so on.
all started from me geting a rave racer sitdown then a jamma cab
now i can not stop looking for arcade cabs to buy lol
sad bit is my flat is 6floors up so can not get any thing to BIG lol
thanx loadz
thanx loadz
There is a program called CHARPROBE that will tell you what keys your pressing.
rite brian
got that porg down and this is wat i get
player 1
cab up = up key
cab down = down key
cab left = left key
cab right = right key
cab butt 1 = control key
cab butt 2 = alt key
cab butt 3 = spacebar
player 2
cab up = r letter
cab down = f letter
cab left = d letter
cab right = g letter
cab butt 1 = a letter
cab butt 2 = s letter
cab butt 3 = q letter
cab player 1 butt = key 1
cab player 2 butt = key 2
cab coin butt = key 5
i hope this helps. carl.
Here are you new Keys
Button 1 = B
Button 2 = Z
Button 3 = M
So map the keys in NULLDC
To the above
Run this program and see if it works.
Keys.zip
Button 1 = B
Button 2 = Z
Button 3 = M
To the above
brill m8 it works 100% with epsxe.
i have got the exe to run when i start a psx game but how do i get the keys.exe to exit when i quit out of epsxe
all sorted thanx for all your help brian
i got autohotkey down and added
control::b
alt::z
space::m
esc::exitapp <---- the esc bit now it exits when i exit epsxe
thanx loads brian for your time m8
needed to add to this
control::b
alt::z
space::m
esc::exitapp
#SingleInstance force <-------- add this line or it trips up in the gameex screensaver mode
just for anyone who dont no! :)
