Hi,
I am a new user of GameEx but seem too be having problems running it, I have installed the frontend , and when i click on the config i get the following messages:
Application has generated an exception that could not be handled
Process id=0xc94 (3220), Thread id=0xcc4 (3268)
after i press cancel i get the following message:
Registered JIT debugger is not available. An attempt to launch a JIT debugger with the following command resulted in an error code of 0x2 (2) Please check computer settings
cordbg.exe !a 0xc94
after i press cancel again i then get the white GameEx nag screen and then the start scrren, when i go into mame and click on update list it updates then i get a black screen and i cannot seem to exit unless i reboot the pc.
AMD Athlon XP 2200+
256 mb Ram
ATI Radeon 9800 Pro series graphics card
OS=XP SP1
can anyone tell me what i am doing wrong
thanks in advance
