i have had this problem a while but havnt had the time to mention it,
i have the escape key programmed in config to exit all emulators except the pc games,
but i needed the config file to map the keys and in the config file the escape to exit button is on false,
and the problem im getting is rarely but sometimes i boot the arcade machine up an go to pc games and when i press escape to change weopen or something the game ends and i get the sound of game over,
it just really got to me as i was right in the middle of a battle online ,ggrrrrrr
any idea's guys :unsure:
Could you use an AHK script to remap your key's for your PC games? Then just launch it along with the game?
I know it would be nicer to get the built in feature working properly but it might save any hassle and pulling your hair out :)
Stu
Stu
Id like to see the emu conig.. Map keys may be enabled.
here is the configs im using
map keys is not enabled <_<
[Emulator_7]
STARTPAGENAME=PC Games 2
TITLETEXT=PC Games 2
StartPageLogo=PC Games 2
ROMFilter=
RomPath=d:\games\links fps
SnapPath=d:\games\links fps\videos
TitlePath=d:\games\links fps\snaps
BoxPath=d:\games\links fps\box art
CartPath=d:\games\links fps\cartridge art
ManualPath=
ControlPanelPath=
InstructionsPath=
WorkingPath=d:\games\links fps
MapKeys=False
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=
AlsoLaunch=
Command=[ROMPath]\[RomFile]
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=Project 64 V2
ExcludedFiles=
CustomBackground=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
SelectionMusicFolder=
PCGame=
DATABASE=
GamesIn7Zips=
PlayInScreenSaver=False
ShowMostPlayed=
RandomMostPlayed=
CDCheck=
CDCheckFile=
[GENERAL]
DumbyValue=
and the map keys are
project 64 v2
# This is an advanced emulator configuration file. It does things such as allow keyboard only emulators to be operated by a gamepad, wait for additional processes to exit and map keys. If this file is used it overrides the MAPKeys setting for the emulator.
[GENERAL]
# Enabled. Use this.
#Make MCE Back button and X-ARCADE Escape and SlikStik Escape to close emulator process
MapBack=FALSE
#Make Escape key close emulator process
MapEscape=FALSE
#When exiting an emulator via the above mappings, you can specify keys in the send keys format to send instead of having GameEx close the process to cleanly exit the emulator. Such as the Q Key or ALT F4 which is %{F4}
KeysToSendOnExit=%{F4}
#Wait for keys to be processed by the emulator
EmuWaitForKeys=True
#Additional processes to wait to exit or close on exit. Dont include the .exe. Leave blank not to use.
Process1=
Process2=
Process3=
Process4=
[JOYMAPPING]
# For mapping a GamePad to keys
# Specify a virtual key code to send when the specific joystick control is pressed. Look at vkcodes.htm for codes.
JoymappingEnabled=True
Left=37
up=38
Right=39
Down=40
Button1=87
Button2=65
Button3=83
Button4=68
Button5=82
Button6=69
Button7=80
Button8=70
Button9=67
Button10=86
[GAMEPADEXIT]
#MAP Gamepad controls to exit and make controls exit process
MapGamePadExit=FALSE
#Flag the controls that exit a game by placing True next to each control. To not use the control as part of the combination use a 0
Left=True
Down=
Right=
Up=True
Button1=
Button2=
Button3=
Button4=True
Button5=True
Button6=True
Button7=
Button8=
Button9=
Button10=
