hi all
im havein probs with daphne and dragons lair sometimes it works then a lot of the time it will not work.
i can get it working from time to time in gameex.
this is what im geting when i try to load. like i say i can get it to work sometimes
i hope some one out there can help me!
DAPHNE version 1.0.0 LOG
--DAPHNE version 1.0.0
--Command line is: Daphne.exe lair vldp -fullscreen -x 640 -y 480 -nohwaccel -framefile c:\Emulators\daphne\framefile\lair_HD.txt
--CPU : AuthenticAMD 2000 MHz || Mem : 512 megs
--OS : Windows NT/2000 || Video : Ultimarc ArcadeVGA2
--OpenGL: Compiled In
--RGB2YUV Function: MMX
--Line Blending Function: MMX
--Audio Mixing Function: MMX
Setting screen width to 640
Setting screen height to 480
Could not initialize video display: DirectInput::CreateDevice: Device not registered <-------------- ( think this is the prob ) but dont no how to fix it.
Video initialization failed!
GAMEEX
[Daphne]
# (http://www.daphne-emu.com/)
# Daphne is a an arcade Laserdisc emulator, that allows playing of
# games such as Dragon's Lair and Space Ace.
# The following options enable GameEx to act as a Daphne front end
# and presents a list of Daphne games that can be selected from the Start
# Page. DaphnePath, and DapnheSnaps should contain the full path to where
# the Daphne ExE is located (path only), and the path to snaps to use.
# Daphne EXE is the daphne executable file (without the path).
# DaphneSnap is the location of Snap Images
# DapnheOptions are the global command line options applicable to all games.
# Set UseDapnhe to true to enable Daphne support in GameEx
UseDaphne=True
DaphnePath=C:\Emulators\daphne
DaphneExe=Daphne.exe
DaphneSnap=C:\Emulators\daphne
DaphneOptions=vldp -fullscreen -x 640 -y 480 -nohwaccel
# Set up the following options for each Daphne Game. Suffix the end of the
# option with an underscore and a number between one and 30. With Each
# game having a seperate number.
# ROMName is the ROM filename
# GameName is the friendly name shown in the GameEx list
# GameOptions are the specific command line options for each game
# Enabled is true or false and whether the game will appear in the list.
Enabled_1 =True
ROMName_1 =lair
GameName_1 =Dragon's Lair
GameOptions_1 =-framefile c:\Emulators\daphne\framefile\lair_HD.txt
Enabled_2=True
ROMName_2 =sae
GameName_2 =Space Ace
GameOptions_2 =-framefile c:\Emulators\daphne\framefile\ace_framefile.txt
Enabled_3=False
ROMName_3 =astron
GameName_3 =Astron Belt
GameOptions_3 =-framefile j:\daphne\mpeg\abelt_framefile.txt
Enabled_4=False
ROMName_4 =cliff
GameName_4 =Cliff Hanger
GameOptions_4 =-framefile j:\daphne\mpeg\cliff_framefile.txt
Enabled_5=False
ROMName_5 =cobraab
GameName_5 =Cobra Command
GameOptions_5 =-framefile j:\daphne\mpeg\cc_framefile.txt
Enabled_6=False
ROMName_6=cobraab
GameName_6=Cobra Command
GameOptions_6=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_7=False
ROMName_7=cobraab
GameName_7=Cobra Command
GameOptions_7=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_8=False
ROMName_8=cobraab
GameName_8=Cobra Command
GameOptions_8=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_9=False
ROMName_9=cobraab
GameName_9=Cobra Command
GameOptions_9=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_10=False
ROMName_10=cobraab
GameName_10=Cobra Command
GameOptions_10=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_11=False
ROMName_11=cobraab
GameName_11=Cobra Command
GameOptions_11=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_12=False
ROMName_12=cobraab
GameName_12=Cobra Command
GameOptions_12=-framefile h:\daphne\mpeg\cc_framefile.txt
GameName_23=
Enabled_13=False
ROMName_13=
GameName_13=
GameOptions_13=
Enabled_14=False
ROMName_14=
GameName_14=
GameOptions_14=
Enabled_15=False
ROMName_15=
GameName_15=
GameOptions_15=
Enabled_16=False
ROMName_16=
GameName_16=
GameOptions_16=
Enabled_17=False
ROMName_17=
GameName_17=
GameOptions_17=
Enabled_18=False
ROMName_18=
GameName_18=
GameOptions_18=
Enabled_19=False
ROMName_19=
GameName_19=
GameOptions_19=
Enabled_20=False
ROMName_20=
GameName_20=
GameOptions_20=
Enabled_21=False
ROMName_21=
GameName_21=
GameOptions_21=
Enabled_22=False
ROMName_22=
GameName_22=
GameOptions_22=
Enabled_23=False
ROMName_23=
GameOptions_23=
DaphneFlyer=C:\Emulators\daphne
DaphneCabinet=C:\Emulators\daphne
DaphneTitle=C:\Emulators\daphne
DaphneMarquee=C:\Emulators\daphne
DaphnePanel=C:\Emulators\daphne
UseGamepad=True
well thanx so much for ya time.
carl.
This may be silly, but how about using the resolution that your descktop is at?
600x800, or whatever it is...
Maybe your video card doesn't support 640x480?
I am just guessing!
Try changing the 640 480 resoultion specified to your actual desktop resolution. Perhaps the card isnt switching resolutions properly.
EDIT: I swear to god I didn't read temepst's post.. We were posting at the same time :)
thanx for the help
this is a bit mad. my dtop is 640 480 and gameex is running in that as well
tryed 600 400 but its not full screen. just tryed 640 480 and 720 480 works one time
then when i do a reboot it will not work anymore i just keep getting the
thanx for the help
Drivers?!? and Direct X update perhaps?!?
oh my god! hehehhe found the prob LAME OR WHAT!
down to a usb mouse.
useing the usb mouse from my main pc to setup dragons lair an gameex then tested the game
to see if its working all was good so id do a reboot and then put my mouse back on my main pc
and hay wat ya no dragons lair dont work! LOL
put the mouse back on my cab-pc and dragons lair works
HOW LAME AM I. :)
thanx for your help anyway
Looks like your off the hook Brian...If you're going to steal my answers, at least steal the one's where I'm actually right! :lol:
And he didn't say "thanx for your help anyway Brian" ;)
Looks like you're trying to play Dragon's Lair High Definition version using an arcadevga & arcade monitor (if that's what lair_HD.txt means). Will this work ?
EDIT: Oops - Missed your post !
