Ok Im haveing some problems with My Vba Emulator.
I have mame set up mame and it is running fine I have now decided to set up some more emulators other then mame so i downloaded Vba and some roms it is now working fine outside of GameEx but :angry:
when i go on to GameEx I Go to "Emulated Games", "[handheld] Nintendo Virtual Boy (reality Boy)"it will then have all my roms listed there but no matter what one i click it will go to a back screen an then exit out :( plz help
so the problem is when ever it try to run roms (VBA roms only) it gose black and then gose back to the screen that i was looking at before
all the roms work out side of game ex
Whats your commandline?
:huh: where can i find that yer im a no hope noob
Run Gameex Configuration.
Find the Vba emulator, then select it. (you will have to click on "Next Page" until you find it)
Click on "next page" until you see Command Line.
Post the information.
Alternately, On the first page of the Vba emulator in the Gameex Configuration program, at the top is a "export" button.
Click on that and save (desktop, wherever...)
open the file, and cut and paste the contents into your next post.
If you do it the second way, it gives more information, and may save us from asking for more stuff later.
dont worry i have worked it all out game Ex was opening it and everything fine but was on top of it so you were not able to see it so i changed it to full screen view and that worked thanks for the help
