Why is gameex so slow
Guest RetroMan
amd athlonXP 2500+ 1gb ram, gforcefx 5600 256mb
gameex worked flawless for me pre 4.73 but since the updates that follow i have nothing but slow downs in the menus.
i have all the lates drivers and scanned and defrag and disabled scanners and more and it is still slow, what did tom do??????????????????????
it is still slow in lower resolutions, turst me i have tried everything humanly possible
try rollback your Nvidia drivers to version 66.93 there are issues with the newer Nvidia drivers and thats not only for Game-ex..
and tell if that did the trick so it can help others there could encounter same problem :)
Also check under tweaks/performance, the Wait Vsync and Reduce CPU Utilization options. Reduce CPU should be either a low number or 0. You can experiment with turning vsync off.
NONE OF THOSE SOLVED MY PROBLEM
HOBO THE CLOWN
Sorry about that Hobo.
Well done RetroMan your the first to get banned from the group. Congratulations. You better hope you dont have a static IP address.
Good Bye.
EDIT: Just for info for anyone, it was the last sentence that did it for me so you dont have to be afraid of being banned! I have enough fun with my young nephews in my family life to want childish and unproductive behaviour for my hobby.
no need to tell the reason imo i would have done the same even a "forum" is a about bebating/argue or impression your thoughts its still a place where you have to respect other people and treat them fair even if they are wrong...
