My NES roms start to load but never get past a blank screen
My log file is
22:24:59.5 21/03/2008: GameEx: Version 9.13: Starting Log
22:24:59.5 21/03/2008: Operating System Platform: Win32NT
22:24:59.5 21/03/2008: Operating System Name: Windows Vista
22:24:59.5 21/03/2008: Operating System Version: 6.0.6000
22:24:59.5 21/03/2008: Vista Aero running
22:24:59.5 21/03/2008: Initializing Vista volume control
22:24:59.5 21/03/2008: Checking for versions of .net Framework installed
22:24:59.5 21/03/2008: .net Framework 1.1 Installed
22:24:59.5 21/03/2008: .net Framework 2.0 Installed
22:24:59.5 21/03/2008: Intel® Core2 Duo CPU E6750 @ 2.66GHz, 2046MB
22:24:59.5 21/03/2008: 2.67Ghz - 2 Cores or CPU's
22:24:59.5 21/03/2008: Running Randomize()
22:24:59.5 21/03/2008: Loading PlugIns
22:24:59.6 21/03/2008: Checking for applications to Launch On Startup
22:24:59.6 21/03/2008: Running Misc startup tasks
22:24:59.6 21/03/2008: Setting Menu types
22:24:59.6 21/03/2008: Opening Configuration File
22:24:59.6 21/03/2008: Getting Configuration Values
22:24:59.6 21/03/2008: Using Theme: Acidbrain Vision
22:24:59.6 21/03/2008: Checking for alternate Image Directory for Theme: Acidbrain Vision
22:24:59.6 21/03/2008: Launching HideOS.exe
22:24:59.6 21/03/2008: Initialising Video/MNG DLL's
22:24:59.6 21/03/2008: Hiding Taskbar
22:24:59.6 21/03/2008: Is Media Center running?
22:24:59.6 21/03/2008: Checking/Creating LCD Registry values
22:24:59.6 21/03/2008: Check Media Center Exit/Start Mode
22:24:59.6 21/03/2008: Media Center Mode 2
22:24:59.6 21/03/2008: Video previews on. Warning: Only recommended on modern systems
22:24:59.6 21/03/2008: Snap Delay set to: 2
22:24:59.6 21/03/2008: Get other settings
22:24:59.6 21/03/2008: Reading MAME hall of fame
22:24:59.7 21/03/2008: Set: Find emulator artwork on best match basis
22:24:59.7 21/03/2008: Start work for Form
22:24:59.7 21/03/2008: Getting Original Screen Size
22:24:59.7 21/03/2008: Opening Database Connection
22:24:59.7 21/03/2008: Initializing Component
22:24:59.8 21/03/2008: Retrieving resolution setting
22:24:59.8 21/03/2008: Creating Radio Station Genres
22:24:59.8 21/03/2008: Succesfully created station genres
22:24:59.8 21/03/2008: Initialising Windows Media Player Component
22:24:59.9 21/03/2008: MAME Path is: E:\Downloads\Mame32
22:24:59.9 21/03/2008: AdvanceMAME Path is: E:\Downloads\AdvanceMAME
22:24:59.9 21/03/2008: AdvanceMAME EXE file is: advmame.exe
22:24:59.9 21/03/2008: Use AdvanceMAME on. advmame.exe will launch games
22:24:59.9 21/03/2008: daphne Path is: E:\Downloads\Daphne
22:24:59.9 21/03/2008: daphne EXE file is: Daphne.exe
22:24:59.9 21/03/2008: Use daphne on. Daphne.exe will launch games
22:24:59.9 21/03/2008: ZiNc Path is: e:\Emulators\ZiNc
22:24:59.9 21/03/2008: ZiNc EXE file is: zinc.exe
22:24:59.9 21/03/2008: Use ZiNc on. zinc.exe will launch PSX games
22:24:59.9 21/03/2008: MAME EXE file is: Mame32.exe
22:24:59.9 21/03/2008: ROM Path is: e:\Downloads\Roms
22:24:59.9 21/03/2008: Catver.ini is located at: E:\Downloads\GameEx\DATA\catver.ini
22:24:59.9 21/03/2008: controls.ini is located at: E:\Downloads\GameEx\data\controls.ini
22:24:59.9 21/03/2008: History.dat is located at: E:\Downloads\GameEx\DATA\history.dat
22:24:59.9 21/03/2008: nplayers.ini is located at: E:\Downloads\GameEx\DATA\nplayers.ini
22:24:59.9 21/03/2008: MAMEinfo.dat is located at: E:\Downloads\GameEx\DATA\mameinfo.dat
22:24:59.9 21/03/2008: Loading Controls.ini map file
22:24:59.9 21/03/2008: Snap Path: Not Found
22:24:59.9 21/03/2008: AVI Snap Path: Not Found
22:24:59.9 21/03/2008: Flyer Path: Not Found
22:24:59.9 21/03/2008: Cabinet Path: Not Found
22:24:59.9 21/03/2008: Title Path: Not Found
22:24:59.9 21/03/2008: PCB Path: Not Found
22:24:59.9 21/03/2008: Artwork Preview Path: Not Found
22:24:59.9 21/03/2008: Panel Path: Not Found
22:24:59.9 21/03/2008: Manual Path: Not Found
22:24:59.9 21/03/2008: Icon Path: Not Found
22:24:59.9 21/03/2008: Marquee Path: Not Found
22:24:59.9 21/03/2008: Loading Custom Emulators
22:24:59.9 21/03/2008: Loading Emulator 4: [Console] Nintendo NES (VirtuaNES)
22:25:00.0 21/03/2008: Using 2D Animations
22:25:00.0 21/03/2008: Using General Font: Trebuchet MS
22:25:00.0 21/03/2008: Using Title Font: Trebuchet MS
22:25:00.0 21/03/2008: Attempting to load game list
22:25:00.2 21/03/2008: Initialising DirectDraw
22:25:00.2 21/03/2008: Applying GameEx is Loading Image
22:25:00.2 21/03/2008: Creating DirectDraw Device
22:25:00.2 21/03/2008: Using Device: NVIDIA GeForce 6500
22:25:00.3 21/03/2008: 886mb video memory available
22:25:00.6 21/03/2008: Setting Resolution to 1024x768 32 bit color
22:25:01.0 21/03/2008: Creating DirectDraw Surfaces
22:25:01.0 21/03/2008: Creating Primary Surface - Full Screen Mode
22:25:01.0 21/03/2008: Creating Back Buffer
22:25:01.1 21/03/2008: Version 2 Theme being used. Loading.
22:25:01.1 21/03/2008: Loading Button Data
22:25:01.1 21/03/2008: Loading Font Data
22:25:01.1 21/03/2008: Loading Layout Data
22:25:01.1 21/03/2008: Loading Taskbar Data
22:25:01.1 21/03/2008: Loading graphic Surfaces
22:25:01.1 21/03/2008: Display is running at: 1024x768 32bit color, 75hz
22:25:01.1 21/03/2008: Creating Surfaces Misc and Dialogs
22:25:01.2 21/03/2008: Creating Surfaces Volume
22:25:01.2 21/03/2008: Creating Surfaces Arrows
22:25:01.2 21/03/2008: Creating Surfaces GameEXlogo Text
22:25:01.2 21/03/2008: Creating Surfaces Toolbar
22:25:01.2 21/03/2008: Creating Surfaces Backgrounds
22:25:01.3 21/03/2008: Creating Surfaces Toolbar Controls
22:25:01.3 21/03/2008: Creating Surfaces GameEx Logo
22:25:01.3 21/03/2008: Creating Surface Unselected
22:25:01.3 21/03/2008: Creating Surfaces Home & Exit
22:25:01.3 21/03/2008: Creating Surfaces Snaps
22:25:01.3 21/03/2008: Creating Surfaces Menu and List Bars
22:25:01.4 21/03/2008: Creating Fonts
22:25:01.4 21/03/2008: Creating Game Font
22:25:01.4 21/03/2008: Creating Menu Font
22:25:01.4 21/03/2008: Restoring Menu Font From Cache
22:25:01.5 21/03/2008: Creating Font Black
22:25:01.5 21/03/2008: Creating Font Black Small
22:25:01.6 21/03/2008: Creating Game Font Faded
22:25:01.6 21/03/2008: Creating Title Font
22:25:01.6 21/03/2008: Restoring Title Font From Cache
22:25:01.7 21/03/2008: Fonts Created Succesfully
22:25:01.7 21/03/2008: 831mb video memory left available
22:25:01.7 21/03/2008: Creating instance of global keyboard hook
22:25:01.7 21/03/2008: Text/Language: English
22:25:01.7 21/03/2008: Applying Language/Text
22:25:01.8 21/03/2008: Initialising Bass Audio Library
22:25:01.9 21/03/2008: MAME CMD options: -triplebuffer -nowindow -joy -skip_gameinfo -nowindow -hwstretch -ddraw
22:25:01.9 21/03/2008: Loading last used Game List
22:25:01.9 21/03/2008: Setting Music Volume
22:25:01.9 21/03/2008: Creating DirectSound Device
22:25:01.9 21/03/2008: Trying: Primary Sound Driver
22:25:01.9 21/03/2008: Loading Sound Files
22:25:01.9 21/03/2008: DirectSound Device Created Successfully
22:25:01.9 21/03/2008: Initialising DirectInput for Gamepad support
22:25:01.9 21/03/2008: Unable to create a joystick device
22:25:01.9 21/03/2008: Playing intro sound file
22:25:02.0 21/03/2008: Initializing MCE Remote
22:25:02.0 21/03/2008: Initialization OK! Starting GameEx!
22:25:02.1 21/03/2008: Testing Main Loop Once: Processing Frame
22:25:02.3 21/03/2008: Testing Main Loop Once: Main Loop ran successfully
22:25:13.6 21/03/2008: Validating: Emulator_4: Custom Background: C:\Emulation\Assets\Console\Nintendo NES\Snaps
22:25:13.6 21/03/2008: Warning: Emulator_4: Custom Background Does not exist
22:25:13.6 21/03/2008: Validating: Emulator_4: Snap Path: C:\Emulation\Assets\Console\Nintendo NES\Snaps
22:25:13.6 21/03/2008: Warning: Emulator_4: Snap Path Does not exist
22:25:13.6 21/03/2008: Validating: Emulator_4: Control Panel Path: C:\Emulation\Assets\Console\Nintendo NES\Controls
22:25:13.6 21/03/2008: Warning: Emulator_4: Control Panel Path Does not exist
22:25:13.6 21/03/2008: Validating: Emulator_4: Instructions Path:
22:25:13.6 21/03/2008: Warning: Emulator_4: Instructions Path Does not exist
22:25:13.6 21/03/2008: Validating: Emulator_4: Database: [Console] Nintendo NES
22:25:13.6 21/03/2008: Validating: Emulator_4: Title Snap Path: C:\Emulation\Assets\Console\Nintendo NES\Titles
22:25:13.6 21/03/2008: Warning: Emulator_4: Title Snap Path Does not exist
22:25:13.6 21/03/2008: Validating: Emulator_4: Box Art Path: C:\Emulation\Assets\Console\Nintendo NES\Boxes
22:25:13.6 21/03/2008: Warning: Emulator_4: Box Art Path Does not exist
22:25:13.6 21/03/2008: Validating: Emulator_4: Cart Art Path: C:\Emulation\Assets\Console\Nintendo NES\Cartridges
22:25:13.6 21/03/2008: Warning: Emulator_4: Cart Art Path Does not exist
22:25:13.6 21/03/2008: Validating: Emulator_4: Manual Path: C:\Emulation\Assets\Console\Nintendo NES\Manuals
22:25:13.6 21/03/2008: Warning: Emulator_4: Manual Path Does not exist
22:25:28.6 21/03/2008: Running: cmd.exe /c E: virtuanes.exe "C:\Users\Mike\Desktop\NES ROMS\Afro Mario Bros (SMB1 Hack) [b1].nes"
22:26:13.2 21/03/2008: Exiting GameEx!
22:26:13.2 21/03/2008: Saving Settings
22:26:14.9 21/03/2008: Disposing Plugins
22:26:14.9 21/03/2008: Closing database connection
22:26:14.9 21/03/2008: Checking for applications to Launch On Exit
22:26:14.9 21/03/2008: Media Center was not open when starting GameEx, so not launching
ok... I prefer the nestopia emulator.. But moving on..
In the emulator config you have options like show desktop.. Try setting this to true.
Also please export your emulator config. You can do the from the advanced configuration. Post the contents here so we can see what your doing.. The log is help full but it doesnt show us everything.
Sample of what I need.
[Emulator_4]
Enabled=False
STARTPAGENAME=Nintendo NES Games
TITLETEXT=NES
StartPageLogo=nes
ROMFilter=*.zip
RomPath=G:\-DATA-\-ROMS-\NES ROMS
SnapPath=
TitlePath=
BoxPath=
CartPath=
ManualPath=
WorkingPath=G:\ROCKNESX\
MapKeys=True
WaitBeforeKeys=3000
SendKeys=%{ENTER}
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=nesemu2.exe [ROMPath]\[RomFile]
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
SelectionMusicFolder=
PCGame=
DATABASE=NES
GamesIn7Zips=False
PlayInScreenSaver=True
ShowMostPlayed=
RandomMostPlayed=
CDCheck=
CDCheckFile=
[GENERAL]
DumbyValue=
[Emulator_4]
STARTPAGENAME=[Console] Nintendo NES (VirtuaNES)
TITLETEXT=Nintendo NES
StartPageLogo=[Console] Nintendo NES
ROMFilter=
RomPath=C:\Users\Mike\Desktop\NES ROMS
SnapPath=C:\Emulation\Assets\Console\Nintendo NES\Snaps\
TitlePath=C:\Emulation\Assets\Console\Nintendo NES\Titles\
BoxPath=C:\Emulation\Assets\Console\Nintendo NES\Boxes\
CartPath=C:\Emulation\Assets\Console\Nintendo NES\Cartridges\
ManualPath=C:\Emulation\Assets\Console\Nintendo NES\Manuals\
ControlPanelPath=C:\Emulation\Assets\Console\Nintendo NES\Controls\
InstructionsPath=
WorkingPath=E:\Downloads\VirtuaNES
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=VirtuaNES.exe "[ROMPath]\[RomFile]"
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
PCGame=False
DATABASE=[Console] Nintendo NES
GamesIn7Zips=False
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=False
CDCheck=False
CDCheckFile=
[GENERAL]
DumbyValue=
If I select Show Desktop=YES it plays in a small screen on the desktop
[Emulator_4]
ROMFilter=
InstructionsPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PCGame=False
GamesIn7Zips=False
ShowMostPlayed=True
CDCheck=False
CDCheckFile=
[GENERAL]
DumbyValue=
Great... now go into the emulator option (not gameex) and tell it to launch the rom full screen. Once that is enabled you will want to launch it from gameex again and verify that it took the settings.. If it does depending on the emu you maybe able to set show desktop back to false.
Your getting closer.
