I have 2 ultimarc 360 joysticks. They both work in mame and Gameex.
In xpadder it recognizes the movement of joystick 1, but doesn't recognize joystick #2 movement at all.
I must be doing somehting wrong.
I am using xpadder because I want joystick supporet for some emulators that aren't working.
There should be a dropdown that shows connected joypads.. Can you select the second joypad and see the controls ?
I have the same config, both the joy work very very well with xpadder.
See also
loriscortina.blogspot.com
If you need help post a more detailed message :)
See also
Your site isn't in English and I couldn't find what you were trying to show.
Anyway, this is the situation:
I have 2 ultimarc joysticks. Xpadder works perfect with joystick 1. When I try to configure joystick #2, it only recognizes joystick #1. What that means is I try to configure joystick #2 by "moving up and then left" and when I move joystick 2, nothing happens...it only registers Joystick #1 and I move up and left.
If I don't use xpadder, my joysticks boith work with Gameex and mame perfectly.
I'm using xpoadder because I want joystick support for other emulators I use.
Thanks!
MAME doesn't work with XPadder unless it's outputs have been sorted out (I haven't checked lately). After the MAMEdevs switched over to the different input system, you pretty much have to use controls however MAME detects them. All other emus should work fine with XPadder, though.
EDIT: I just checked, and it looks like the features that would allow you to use XPadder with MAME will be incorporated at some point when the "T.Rex" version is released. I don't follow the XPadder forums, so I can't comment further, but it's supposed to be released some day...
As usual, Brian's right!
Open Xpadder, and click on the wrench on the left. (I mean right, in addition to everything else, I'm also cixelsyd) :P
That will open a window, and on the far right is a tab for controllers.
I only have one U360, and its shown there...Do you have 2 U360's in that Tab?
Then click on the Xpadder icon on the left side of the xpadder window. That will bring up a menu, go to settings.
In the controller settings window, click on the "sticks" Tab. On this tab, you will be able to enable, and configure your U360's
Again, I don't have two U360's, but hopefully, that will help!
I got it.
What you have to do is for joystick 1 config you have to have "A" selected. Then to set up the 2nd controller, select "B"
A and B are 2 tabs on the top right corner of main xpadder window...as shown in the attached photo.
THANKS!
Anyone have a good Ultimarc 360 + buttons picture to use in xpadder?
