G'Day,
I have recently downloaded GameEx for the first time. I set it up with no issues and it launches my mame32plus stuff perfectly. After a reboot, upon launching GameEx it crashes and I get the following log entries. I have the same problem on three different PCs. They all run genuine XP. I have run diagnostic software on the ram and HD with no errors detected.
Any help would be greatly appreciated.
18:52:03.1 7/03/2008: Playing intro sound file
18:52:03.1 7/03/2008: --**--
18:52:03.1 7/03/2008: Error: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
18:52:03.2 7/03/2008: at System.Drawing.SafeNativeMethods.Gdip.GdipCreateBitmapFromScan0(Int32 width, Int32 height, Int32 stride, Int32 format, HandleRef scan0, IntPtr& bitmap)
18:52:03.2 7/03/2008: at System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format)
18:52:03.2 7/03/2008: at System.Drawing.Bitmap..ctor(Int32 width, Int32 height)
18:52:03.2 7/03/2008: at l.a(Boolean A_0, String A_1, Boolean A_2)
18:52:03.2 7/03/2008: at l..ctor()
18:52:03.2 7/03/2008: Closing database connection
18:52:03.2 7/03/2008: GameEx is exiting with errors
18:52:05.2 7/03/2008: ERRORS DETECTED: EXITING
G'Day,
Are they all the same brand pc? or are alll of them infected with the same viruses? (meaning do you share files amongst these pc's) its a strange problem to have.. Especially on diffrent machines. Can you tell us a little about your hardware?
thanks
thanks
I have this same problem on 3 PCs.
2 x Intel P4 on Intel mainbords, 500Mb Ram, XP Home 2002. AVG Free, Sybot S&D.
1 x Lenovo Intel core 2 T5600 @ 1.8GHz Notebook, 1G ram, XP Pro SP2. AVG Free, Sybot S&D.
These PCs are networked and I have copied my mame32plus installations across to each.
A virus is definately possible, but I have no other symptoms.
Full log attached.
Oh, and if I "delete all game data", I am able to launch GameEx. I can then Update the game list and all is fine.....until I reboot and then the error appears again.
Thanks,
Moose.
3 PC's with the same problem and I have never seen this error before. Looks like it could be a virus I'm afraid. Run a virus scanner and SpyBot S&D.
BTW What codecs are you using for video playback?
Full log attached.
Thanks,
Moose.
Do you have the tea timer on with SBSD?
That's a good thought. I had some problems when I used SpyBot and one of it's add-ons (perhaps it was called Tea Timer). Try running without either anti-virus package and see if that helps.
I do have tea timer running.
I will remove it first and see if that fixes it. Maybe tea timer is messing around with something. Then I might try removing any other common programs.
Thanks guys. I will let you know.
Moose.
