13th August 2005
- GameEx 4.80
  • Attract mode enhancements:
    • Can play videos, ie
      commercials.
    • recommended with the
      MAMEWAH commercial pack from http://www.emumovies.com
    • Can specify ratio of
      videos to games
    • Can now specify how long
      each game stays running for
    [*]Jukebox now features
    visualisations.
    [*]Fix: GameX remembers window
    position after returning from being minimized.
    [*]Should fix GameEx loosing
    focus on older PC's
    [*]Should fix Mouse not working
    after ALT-Tabbing and returning to GameEx full
    screen.
    [*]Fix: Fonts are recreated at
    the correct size when Maximizing and you've told
    GameEx not to set resolution.
    [*]Fix: Gamepad support is
    turned off when no gamepad found. This could fix
    various issues when launching MAME games and other
    use.
    [*]Emulators are better
    organised in the config app.
    [*]Attract mode has its own
    section in config app.
Attract mode is like a screen saver. If you leave GameEx and don't pick a game for a while, it will start running random games (or with the new version, possibly playing videos).
Forgot:
Windows shortcuts are now supported for emulators. GameEx can read and process the contents of the shortcut file and launch the exe appropriately with support for map keys.
