i have Virtual Coleco working, problem is I have roms with the .col extension.
The only games that work are of the type: ColoecoVision Game Rom
How do I convert .col to that or where do i get the correct roms...
THANKS!
rename the extension....or just switch over to a different emulator...Meka, Mess, BlueMSX, ColEm...probably a few others out there.
Tried to rename the extension (actually just removed the .col ) and no luck
any ideas???
don't remove the extension...rename it....so go from .col to .rom and try again.
So back to what I said before...and if you don't want to go through all that hassle...use a different emulator.
