I've been running into an issue where the GameExtender viewer seems to stop refreshing the info posted on the screen and remains stuck in the last Mame game that it had collected data from.
I have a dual mon setup with GameExtender App running on the secondary monitor. It seems to run ok for awhile but over time (30 mins or so?) it will just stop refreshing the screen and get stuck on the last update (usually is a mame title)
GameEx 9.03
WinXP MCE 2005
P4 2.4 duo
plz let me know what other config/logs you need from me.
Thanks!
-n8
Please post your GameEx.log (Start > Programs > GameEx > Log File)
Of course after i post a bug report I began messing with the settings a bit and extended the refresh time to 10 seconds instead of the default 3 sec and things appear to be running smoothly so far (the past 2 hours or so). I'll keep monitoring it and see if i can come up with a repro and post the details back here... If things run good for 1 day or so, i'll try dropping back to 3 sec refresh update and see if i can get another repo.
Thanks!
-n8
