Ok, I'm new to commandline emulators (aside from DosBox, which is very easy) and also new to GameEx. To be honest, the only reason I installed GameEx was an attempt to get VJ to work.
First off, I'm running vista (32-bit). When I double click the VJ.exe file, the mouse cursor blinks a few times and then that's it. It never loads. I saw in an old post at these forums to turn off UAC in Vista. I did that. Same problem. So I downloaded GameEx. When I try to run it in gameex, the screen goes black, glitches a few times, and then boots me back to gameex. (The game I'm trying to load is Alien VS Predator).
I found an old topic here at these forums that listed a config for use in GameEx for VJ 1.0.7. I tried that, it still doesn't work.
I downloaded Project Tempest v0.95, and it plays AvP, but the graphics are very glitchy, joypad support is all but non-existant for dual analogue stick gamepads, and when playing the predator, the two visions that are the clearest when invisible screw up the game resolution so that you can only see half the screen. Ugh.
I'm using a Dell Inspiron 1720 laptop, Intel Duo Core 2.0 ghz, 3 gb RAM, geforce 8600M GT (256 mb vram)
I want to be able to play this game desperately, and I'm pulling my hair out over here. Any help would be GREATLY appreciated.
Just in case it might be helpful, I'll list here both the GameEx config AND the VJ config.
GameEx:
[Emulator_8]
DumbyValue=
STARTPAGENAME=Atari Jaguar (Virtual Jaguar)
TITLETEXT=Atari Jaguar
StartPageLogo=Jaguar
ROMFilter=
RomsInFolders=False
RomPath=C:\Emulation\Atari Jaguar\virtualjaguar-1.0.7\roms
SnapPath=
TitlePath=
BoxPath=
CartPath=
WorkingPath=C:\Emulation\Atari Jaguar\virtualjaguar-1.0.7
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=False
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=vj.exe "[ROMPath]\[RomFile]"
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
Database=[Console] Atari Jaguar
GamesIn7Zips=
VJ config:
# Virtual Jaguar configuration file
# Jaguar BIOS options: 1 - use, 0 - don't use
useJaguarBIOS = 1
# Jaguar ROM paths
JagBootROM = ./bios/jagboot.rom
CDBootROM = ./bios/jagcd.rom
EEPROMs = ./eeproms
ROMs = ./ROMs
# OpenGL options: 1 - use OpenGL rendering, 0 - use old style rendering
useOpenGL = 1
# OpenGL filtering type: 1 - blurry, 0 - sharp
glFilterType = 0
# Display options: 1 - fullscreen, 0 - windowed
fullscreen = 1
# NTSC/PAL options: 1 - NTSC, 0 - PAL
hardwareTypeNTSC = 1
# DSP options: 1 - use, 0 - don't use
DSPEnabled = 1
# If DSP enabled, set whether or not to use the pipelined core: 1 - use, 0 - don't use
usePipelinedDSP = 0
# Joystick options: 1 - use joystick, 0 - don't use
useJoystick = 0
# Joyport option: If joystick is enabled above, set the port (0 - 3) here
joyport = 0
# Jaguar joypad key assignments
# Note: It would be nicer to be able to have a single left side to store all this in...
# E.g. p1keys = 34, 32, 22, etc. instead of what we have here...
p1k_up = 273 # SDLK_UP
p1k_down = 274 # SDLK_DOWN
p1k_left = 276 # SDLK_LEFT
p1k_right = 275 # SDLK_RIGHT
p1k_c = 122 # SDLK_z
p1k_b = 120 # SDLK_x
p1k_a = 99 # SDLK_c
p1k_option = 39 # SDLK_QUOTE
p1k_pause = 13 # SDLK_RETURN
p1k_0 = 256 # SDLK_KP0
p1k_1 = 257 # SDLK_KP1
p1k_2 = 258 # SDLK_KP2
p1k_3 = 259 # SDLK_KP3
p1k_4 = 260 # SDLK_KP4
p1k_5 = 261 # SDLK_KP5
p1k_6 = 262 # SDLK_KP6
p1k_7 = 263 # SDLK_KP7
p1k_8 = 264 # SDLK_KP8
p1k_9 = 265 # SDLK_KP9
p1k_pound = 267 # SDLK_KP_DIVIDE
p1k_star = 268 # SDLK_KP_MULTIPLY
p2k_up = 273 # SDLK_UP
p2k_down = 274 # SDLK_DOWN
p2k_left = 276 # SDLK_LEFT
p2k_right = 275 # SDLK_RIGHT
p2k_c = 122 # SDLK_z
p2k_b = 120 # SDLK_x
p2k_a = 99 # SDLK_c
p2k_option = 39 # SDLK_QUOTE
p2k_pause = 13 # SDLK_RETURN
p2k_0 = 256 # SDLK_KP0
p2k_1 = 257 # SDLK_KP1
p2k_2 = 258 # SDLK_KP2
p2k_3 = 259 # SDLK_KP3
p2k_4 = 260 # SDLK_KP4
p2k_5 = 261 # SDLK_KP5
p2k_6 = 262 # SDLK_KP6
p2k_7 = 263 # SDLK_KP7
p2k_8 = 264 # SDLK_KP8
p2k_9 = 265 # SDLK_KP9
p2k_pound = 267 # SDLK_KP_DIVIDE
p2k_star = 268 # SDLK_KP_MULTIPLY
Project Tempest is likely your best bet...now its my understanding that v0.94 supported gamepads so you may want to go hunting for an older build of it. However I'd just setup Xpadder to work with it.
Really I'd like you to keep in mind that the jaguar never was emulated very well...so having it setup is mainly just for show...nothing more.
In the 101 reasons thread I have some loaders written up for use with PT...which I would suggest giving a try to help out...but things will still suck.
