No idea what is happening but has been happening since after the .66 build
seems to load up then the screen goes black and then I go back to the desktop (if not already in MCE). Always gets to the same spot in the log too :
18:38:03.0 8/2/2005: GameEx: Version 4.72: Starting Log
18:38:03.0 8/2/2005: Operating System Platform: Win32NT
18:38:03.0 8/2/2005: Operating System Name: Windows XP
18:38:03.0 8/2/2005: Operating System Version: 5.1.2600
18:38:03.0 8/2/2005: Running Randomize()
18:38:03.0 8/2/2005: Running Misc startup tasks
18:38:03.0 8/2/2005: Hiding Cursor
18:38:03.0 8/2/2005: Setting Menu types
18:38:03.1 8/2/2005: Opening Configuration File
18:38:03.1 8/2/2005: Getting Configuration Values
18:38:03.1 8/2/2005: Using Theme: Default - GameEx
18:38:03.1 8/2/2005: Checking for alternate Image Directory for Theme: Default - GameEx
18:38:03.1 8/2/2005: Text/Language: English
18:38:03.1 8/2/2005: Applying Language/Text
18:38:03.1 8/2/2005: Creating Scancodes.txt (List of DirectInput scan codes)
18:38:03.1 8/2/2005: Snap Delay set to: 1
18:38:03.1 8/2/2005: Is Media Center running?
18:38:03.1 8/2/2005: Check Media Center Exit/Start Mode
18:38:03.1 8/2/2005: Media Center Mode 2
18:38:03.1 8/2/2005: Checking for applications to Launch On Startup
18:38:03.1 8/2/2005: Get other settings
18:38:03.1 8/2/2005: SlikStik support enabled
18:38:03.1 8/2/2005: Launching HideOS.exe
18:38:03.9 8/2/2005: Hiding Taskbar
18:38:03.9 8/2/2005: Start work for Form
18:38:03.9 8/2/2005: Getting Original Screen Size
18:38:03.9 8/2/2005: Loading ICON
18:38:04.0 8/2/2005: Initializing Component
18:38:04.0 8/2/2005: Initialising Bass Audio Library
18:38:04.1 8/2/2005: Loading default loading screen
18:38:04.1 8/2/2005: Using General Font: HandelGothic BT
18:38:04.1 8/2/2005: Using Title Font: HandelGothic BT
18:38:04.1 8/2/2005: Initialising DirectDraw
18:38:04.1 8/2/2005: Creating DirectDraw Device
18:38:04.1 8/2/2005: Using Device: RADEON X850 Series
18:38:04.2 8/2/2005: Setting Resolution to 1280x960 32 bit color
18:38:04.2 8/2/2005: Creating DirectDraw Surfaces
18:38:04.2 8/2/2005: Creating Primary Surface - Full Screen Mode
18:38:04.2 8/2/2005: Creating Back Buffer
18:38:04.2 8/2/2005: Loading graphic surfaces
18:38:04.2 8/2/2005: Creating Surfaces Misc and Dialogs
18:38:04.3 8/2/2005: Creating Surface Volume
18:38:04.3 8/2/2005: Creating Surfaces Arrows
18:38:04.3 8/2/2005: Creating Surfaces GameEXlogo Text
18:38:04.3 8/2/2005: Creating Surfaces Toolbar
18:38:04.3 8/2/2005: Creating Surfaces Backgrounds
18:38:04.8 8/2/2005: Creating Surfaces Toolbar Controls
18:38:04.8 8/2/2005: Creating Surfaces GameEx Logo
18:38:04.8 8/2/2005: Creating Surfaces Home & Exit
18:38:04.8 8/2/2005: Creating Surfaces Snaps
18:38:04.8 8/2/2005: Creating Surfaces Menu and List Bars
18:38:04.8 8/2/2005: Creating Fonts
18:38:04.8 8/2/2005: Creating Menu Font
18:38:05.2 8/2/2005: Creating Game Font
18:38:05.6 8/2/2005: Creating Game Font Faded
18:38:05.9 8/2/2005: Creating Title Font
18:38:06.6 8/2/2005: MAME Path is: C:\MAME
18:38:06.6 8/2/2005: daphne Path is: C:\Daphne
18:38:06.6 8/2/2005: daphne EXE file is: Daphne.exe
18:38:06.6 8/2/2005: Use daphne on. Daphne.exe will launch games
18:38:06.6 8/2/2005: MAME EXE file is: Mame32.exe
18:38:06.6 8/2/2005: ROM Path is: C:\MAME\roms
18:38:06.6 8/2/2005: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
18:38:06.6 8/2/2005: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
18:38:06.6 8/2/2005: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
18:38:06.6 8/2/2005: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
18:38:06.6 8/2/2005: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
18:38:06.6 8/2/2005: Loading Controls.ini map file
18:38:06.6 8/2/2005: Loading Custom Emulators
18:38:06.6 8/2/2005: Loading Emulator 1: Nintendo 64 Games
18:38:06.6 8/2/2005: Loading OfflineList Dat File for emulator: 1
18:38:06.6 8/2/2005: Cannot Find Offline List Dat File
18:38:06.7 8/2/2005: Loading Emulator 2: Nintendo SNES games
18:38:06.7 8/2/2005: Loading Emulator 4: Nintendo NES Games
18:38:06.7 8/2/2005: Loading Emulator 5: Atari 2600 Games
18:38:06.7 8/2/2005: Loading Emulator 6: PC Games
18:38:06.7 8/2/2005: Loading Emulator 7: Sega Genesis Games
18:38:06.9 8/2/2005: Snap Path is: C:\MAME\snap
18:38:06.9 8/2/2005: AVI Snap Path is: C:\MAME\samples
18:38:06.9 8/2/2005: Flyer Path is: C:\MAME\flyers
18:38:06.9 8/2/2005: Cabinet Path is: C:\MAME\cabinets
18:38:06.9 8/2/2005: Title Path is: C:\MAME\titles
18:38:06.9 8/2/2005: Panel Path: Not Found
18:38:06.9 8/2/2005: Icon Path is: C:\MAME\icons
18:38:06.9 8/2/2005: Marquee Path is: C:\MAME\marquees
18:38:06.9 8/2/2005: MAME CMD options: -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy
18:38:06.9 8/2/2005: Attempting to load game list
18:38:06.9 8/2/2005: Running: Mame32.exe -help
18:38:06.9 8/2/2005: Running: C: C:\MAME\Mame32.exe -help > C:\MAME\help.txt
18:38:07.0 8/2/2005:
18:38:07.0 8/2/2005: Now Outputing Mame32.exe - Help
18:38:07.0 8/2/2005: --BEGIN--
18:38:07.0 8/2/2005: M.A.M.E. v0.88 (Oct 24 2004) - Multiple Arcade Machine Emulator
18:38:07.0 8/2/2005: Copyright © 1997-2004 by Nicola Salmoria and the MAME Team
18:38:07.0 8/2/2005: MAME is an emulator: it reproduces, more or less faithfully, the behaviour of
18:38:07.0 8/2/2005: several arcade machines. But hardware is useless without software, so an image
18:38:07.0 8/2/2005: of the ROMs which run on that hardware is required. Such ROMs, like any other
18:38:07.0 8/2/2005: commercial software, are copyrighted material and it is therefore illegal to
18:38:07.0 8/2/2005: use them if you don't own the original arcade machine. Needless to say, ROMs
18:38:07.0 8/2/2005: are not distributed together with MAME. Distribution of MAME together with ROM
18:38:07.0 8/2/2005: images is a violation of copyright law and should be promptly reported to the
18:38:07.0 8/2/2005: authors so that appropriate legal action can be taken.
18:38:07.0 8/2/2005: Usage: MAME gamename [options]
18:38:07.0 8/2/2005: MAME -list for a brief list of supported games
18:38:07.0 8/2/2005: MAME -listfull for a full list of supported games
18:38:07.0 8/2/2005: MAME -showusage for a brief list of options
18:38:07.0 8/2/2005: MAME -showconfig for a list of configuration options
18:38:07.0 8/2/2005: MAME -createconfig to create a mame.ini
18:38:07.0 8/2/2005: For usage instructions, please consult the file windows.txt
18:38:07.0 8/2/2005: --END--
18:38:07.0 8/2/2005: Loading last used Game List
18:38:07.2 8/2/2005: Cannot Load Play List. Check Path and filename
18:38:07.2 8/2/2005: Creating DirectSound Device
18:38:07.2 8/2/2005: Trying: Primary Sound Driver
18:38:07.2 8/2/2005: Loading Sound Files
18:38:07.2 8/2/2005: DirectSound Device Created Successfully
18:38:07.2 8/2/2005: Creating ICONS
hmmm finally dawned on me what Icons it was talking about and fixed it by removing my ICONS path for MAME... dunno whats wrong though.....
doesnt like the zip file all of the sudden?
Hi, it does not work with ZIPS. Thats the reason.
Actually my bad, I left in some debugging code that closed the application if no icons where found. Will be fixed next release. whoops!
Thanks! I just loaded .72 last night and found that I had the same problem. I was wondering what I was losing not having the path specified for the Icons...
I like the new Splash screen and RSS feeds (I was several releases behind)!
Tom, I have an X-arcade console connected to my cabinet. Have you added anything specific for using this now that you have one?
Thanks!
Thanks!
Yes I have, you can now exit games by pressing Player 2 and right flipper together.
The ICON issue is fixed in 4.73 (uploaded Today).
