Can Someone plz tell me how to get Visual Pinball to work correctly in Game Ex? I am running Windows Vista Ultimate. I found and downloaded a guide did everything it said but the pinball tables still won't run. Do you need something called a wrapper to do this? headkaze I like the new LED-Wiz plugin. It is gonna take some doing for all the neogeo games to light buttons correctly but I love it!!!
Hey mate no need to create cfg's for each neogeo game. All you have to do is use a ctrlr file and put an entry in for neogeo and it will light them correctly (I have it working this way on my cab) :)
Read about it here
Attached are the Visual Pinball configs I use
PinballConfigs.zip
Read about it here
Thanx I'ma give these a go after I reinstall everything. I had to revert back to XP cause Vista kept crashing and random rebooting. I'll probably have to do the game by game thing. It'll take time but oh well if I do 15 or so a day I'll get everything I play done eventually. One more thing if I don't do an indvidual game config file none of the buttons light up. Any way to fix this? Also is daphne supported for in game lighting?
Not sure why you think you need to do the game by game thing. It's really not necessary with a ctrlr file.
If you don't have an individual game profile, you should make one for GameEx->Default and possibly one for each [Emulator]->Default. If it doesn't have a game profile it should revert back to these. A GameEx->Default profile is all you really need to have to fall back on.
No Daphne support as of yet. I have to talk to Tom about how this works in GameEx before I can add it to the plugin.
Hey thanx for the pinball configs. I noticed some things were off in the default setting so I manually added the changes and now visual pinball works great! my controls even light up!
