hello
I don't try to do a configure daemon tool on emulator (magic engine ssf neo geo cd...)in set up wizard 1.83 a message error
is launch before:''C:/Program Files DAEMON Tolls daemon.exe -mount 0,''(RomPath) (RomFile)''' does not exit
my config is:
StartPageName=NEC TurboGrafx CD (Magic Engine)
TitleText=NEC TurboGrafx CD
StartPageLogo=TGCD
RomFilter=*.ink
RomsInFolders=False
ROMPath=C:\Roms\NEC TurboGrafx CD
SnapPath=
TitlePath=
BoxPath=
CartPath=
WorkingPath=C:\Emulators\MagicEngine
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=False
Debug=False
MapFile=
AlsoLaunch=
Command=pce.exe "syscard3.pce"
OLDatZip=
LaunchBefore=C:\Program Files\DAEMON Tools\daemon.exe -mount 0,"[RomPath]\[RomFile]"
LaunchAfter=C:\Program Files\DAEMON Tools\daemon.exe -unmount 0
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
Database=[Console] NEC TurboGrafx CD
GamesIn7Zips=
please help me
hello
my config is:
StartPageLogo=TGCD
RomFilter=*.ink
RomsInFolders=False
SnapPath=
TitlePath=
BoxPath=
CartPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=False
Debug=False
MapFile=
AlsoLaunch=
OLDatZip=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
GamesIn7Zips=
please help me
what exactly does not exist? Deamon tools? Please post the contents of your runlastgame.bat it can be found in the gameex programs group in the start menu... Aslo you may want to run that as you may be able to see the error.
they tell me that C:/Program is not recognized as an internal or external command or as an executable program
daemon tool doesn't want to mount any isos
Use quotes "C:/Program Files\deamon tools\deamon tools.exe"
Dos hates spaces.... use Quotes to define a path where there are spaces.
please give me an exemplary with deamon tool in your config just to me see I have everything to try to config a daemon tool
"C:\Program Files\D-Tools\daemon.exe" -mount 0,"[rompath]/[romfile]"
or
LaunchBefore="C:\Program Files\DAEMON Tools\daemon.exe" -mount 0,"[RomPath]\[RomFile]"
LaunchAfter="C:\Program Files\DAEMON Tools\daemon.exe" -unmount 0
I donot believe newer installs use the same path so be sure to change accordingly
Leave the quotes intact though
