I have enabled the jukebox and added songs to my Media player playlist and library but i am unable to see anything relating to the jukebox once i am in Gameex
Any ideas?
Any ideas?
Have you got a recent version of Windows Media Player?
It should be under Multimeida - jukebox.
If no music shows up select the All Music Playlist
Did that help?
hmmm my "jukebox" disapered as well the only thing i did was remove in media-player the libary files for making a new play list .. after that the "jukebox" option are gone in Game-Ex
Sorry, what exactly did you remove?
just the "libary" song-list in media player and now the Jukebox are gone im Game-Ex the radio tho works fine...
Any ideas?
Also, did you add music to the library with the same Windows User you are using GameEx as?
I just get no music found when i do that, I still have the Jukebox there. What version of WMP are you using?
im using WMP version 10.00.00.3646
WMP worked as a charm before i did that wonder if i upgraded to Game-Ex to 4.71 i will look the .ini through
Edit : well it was correct nothing there was wrong in it but i loaded the GameExConfig.exe and changed nothing just pressed "save" and runned Game-Ex and the jukebox was back :)
I have the latest version and have all my songs in the library. nothing shows up in the multimedia except Radio, Picture and DVD
