I really love all the features in GameEx (videos, dat support, jukebox, etc). However, I've been banging my head against the wall trying to get NullDC to work, even with the various loaders floating around on the forums here.
But tonight I made a relatively simple discovery. I apologize if it's obvious and been discussed before, but it's the only thing that worked for me, so I thought I'd share. The other threads I've found that mention this line in the NullDC config do so in conjunction with scripts or loaders, and still have problems with exiting. At least on my machine with this config, the exit routine also works perfectly.
First, I'm using NullDC 1.6 and Daemon Tools 4.10.
- Setup Daemon Tools to create a virtual drive, note the drive letter for the new drive, and turn all options off.
- Open NullDC outside of GameEx and configure it the way you want -- making sure to configure the controls, enable fullscreen in NullPVR, and select the GDRom plugin and set it to the drive letter that Daemon Tools creates.
- In the main NullDC file folder, there should be a file called nullDC.cfg. AFTER you've configured NullDC completely, open this file in Notepad and change the option Emulator.AutoStart=0 to Emulator.AutoStart=1
- Setup the emulator in GameEx to match this, editing your paths of course to match where you store your roms and emulators.
[Emulator_]
StartPageName=Sega Dreamcast
TitleText=Sega Dreamcast
StartPageLogo=Dreamcast
RomFilter=*.b5t;*.bin;*.bwt;*.ccd;*.cdi;*.iso;*.mds;*.nrg;*.pdi
RomsInFolders=False
ROMPath=C:\Emulation\ROMS\Dreamcast
SnapPath=
TitlePath=
BoxPath=
CartPath=
WorkingPath=C:\Emulation\nulldc_100b1_6
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=False
Debug=False
MapFile=
AlsoLaunch=
Command=nullDC_100b1_6.exe
OLDatZip=
LaunchBefore=""C:\Program Files\DAEMON Tools\daemon.exe" -mount 0,"[RomPath]\[RomFile]""
LaunchAfter="C:\Program Files\DAEMON Tools\daemon.exe" -unmount 0
configFile=[Mapping On] Exit nullDC (Process Close)
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
GamesIn7Zips=False
ManualPath=
PlayInScreenSaver=False
ShowMostPlayed=False
RandomMostPlayed=True
CDCheck=False
CDCheckFile=
lastgame=
DontShowInfo=
PlaySelectionMusic=
SelectionMusicFolder=
Anyway, your mileage may vary, but this works perfectly for me.
It DOES work! Well it actually loads and plays pretty well which is more than I can say for all the other wrappers and configs (no offense) but there are a few little hang ups-
Did you notice a significant decrease in fps? I'm not sure if it is game ex itself or the gdrom plug in but games were pretty slow as compared to running outside gameex.
Also I never used the gdrom plug-in but may have an alternate method for running games. I can't write code but here are the basics.
Instead of using daemon tools why not use the image reader plug in and have it pointed to:
Options>GDROM>select default image
then you would pick it then go to
System>start>
then select image again
I didn't have to use daemon tools after using that plugin but would have no idea how to incorporate that into gamex. Just a suggestion, excellent work though I've been struggling with Dreamcast for a LONG time.
T. Goodchild
This is what you want. (KeithDok took this method another direction as Daemontools supports more formats and compressed iso's)
http://www.gameex.info/forums/index.php?s=...ost&p=30042
Just make sure the exe name is correct... As I figured this out for the 1.5 beta but it does work for 1.6
Also in pervious betas of this emulator it forced 60 hz or fps
So if your DC logo is BLUE (PAL) or your playing a PAL game it will run at 50 hz 50 fps
There is a way aroud this and that is to go into the nullpvr and goto output and force vga 0 I believe... not use TV which i believe is default
Im pretty sur its the last option... I had the same issue with MVC2 it just seemed slower... That fixed it
Happy gaming
EDIT: I went ahead and just pulled the text
GETTING NULL DC to LAUCH VIA GAMEEX commandline
Find the Nulldc.cfg in the INSTALL DIR. look for these tags
[imageReader]
DefaultImage=
PatchRegion=0
LoadDefaultImage=1
[nullDC]
Dynarec.Enabled=1
Dynarec.DoConstantPropagation=1
Dynarec.UnderclockFpu=0
Dreamcast.Cable=3
Dreamcast.RTC=1543276800
[drkpvr]
Emulation.AlphaSortMode=1
Emulation.PaletteMode=1
Emulation.ModVolMode=1
OSD.ShowFPS=0
OSD.ShowStats=0
Fullscreen.Enabled=1
Fullscreen.Res_X=640
Fullscreen.Res_Y=480
Fullscreen.Refresh_Rate=60
Enhancements.MultiSampleCount=0
Enhancements.MultiSampleQuality=0
Enhancements.AspectRatioMode=1
NOW SAVE THE NULLDC CONFIG AND GO INTO THE GAMEEX CONFIG
(in gameex config)Command=nulldc_100b1_6.exe -config ImageReader:DefaultImage="[rompath]/[romfile]"
I'm having a couple of issues. Can someone show me a config to use with Alcohol 120%. If I don't use a wrapper will the mouse still hide with 1.6? I'm unable to configure this to work with my ipac. How do I set the keys up? Thanks.
If you do not use a wrapper then your mouse will not auto hide...
However I use this in my gameex startup. It works wonders
Its called no mousy
http://www.apps4apps.filetap.com/nomousy.html
Also the keys are configured using the maple plugin.. :)
  • 6 months later...
Its called no mousy
Hi Brian
Tried putting the no mousy in the launch before of my Ini for NUlldc but it doen't hide the mouse, what am i doing wrong.
  starbuck said:
Hi Brian
Brian helped me with this so I'll chime in. Try putting it under Launch Also instead of Launch Before and/or run it as part of a batch file. I run mine from a batch file (to open xpadder also) that I target under Launch Also. Seems to work better than Launch Before.
@echo
start /d "c:\Program Files\xpadder" xpadder.exe dcp2 dcp1 p1 p2
start /d "c:\Program Files\nomousy1.5\ nomousy.exe /h
exit
No matter where it is be sure to use the /h commandline switch. Run nomousy.exe batch by itself under Launch After to restore. Note, I think the /d above is for Vista only.
Guess I'm having a blonde moment. Can't seem to get the cursor to hide. Running the following batch file under Launch Also.
@echo
start "c:\Program Files\GameEX\Utilites\No Mousy\"nomousy.exe /h
exit
Running the following batch file in the launch after to save my nulldc config
del nulldc.cfg
copy nulldcbackup.cfg nulldc.cfg
"C:\Program Files\GameEx\Utilities\No Mousy\"nomousy.exe
end
also every time i start a game in Nullcd I have to put in the current date.
@echo
exit
del nulldc.cfg
end
Try putting the quotes after the executable. So will look like the following.
start "c:\Program Files\GameEX\Utilites\No Mousy\nomousy.exe" /h
