Hello,
I noticed something the other day. If I use version 0.84 with gamex it does not keep my analog settings when i exit a game. If I use 0.85 or higher it does. Any suggestions? I want to use version 0.84 because it was the last version that had the GOOD speedup cheat for MS. Pacman
forgot to mention I tried doing a install on a completely different machine using 0.84 and had the same problem. If I use 0.85 version of mame everything works. In the meantime I just added a launch for Ms. Pacman (version 0.84) in the Other games menu
Are you saying its a GameEx issue?
