  TSpeirs said:
Rob, if you have no motivation to work with me on this, its totallly fine, I can still do it no problem, I just thought you might get a kick out of it.
Cheers.
Tom
Hi Tom,
Yes! I would absolutely LOVE to handle this aspect for your official product. You've probably noticed that I have put a lot of thought into my current "script", and would be very pleased to re-create it in a proper way in C# for the official product.
Give me a basic rundown of how you'd like it to work (basic config structure you'd like to see, where to pull it from, parameters, etc) and I'll run with it from there.
I've added "built-in" joy-to-key mappings to my app now too, BTW. I'm using it so I can play VPinmame with my gamepad. Trying to avoid needing lots of little helper scripts for different apps. I think I've worked through most of the quirky scenarios that are needed at this point.
EMKO,
Please post the contents of your batch file that calls KeyMonitor.exe. It must be exactly as I posted above in order for it to work.
-- Rob
Okay, now when you say it "does the exact same thing", on the first try, what exactly is it doing? Is GameEx returning immediately, or is it not returning when you exit?
If does not return on exit, if you press ctl-alt-del to look at the task list, did epsxe really fully exit? Is Keymonitor.exe still running?
ok this is exactly what happens when i press esc
i cant see my start menu but i can see my desktop shortcuts when i press ctl-alt-del i see cmd.exe and gameex.exe running i dont see epsxe.exe or Keymonitor.exe
the only way to get back to gameex is to close cmd.exe
i removed that and it doesnt make a difference
i tryed removeing LaunchAfter=pause
this causes my first problem when gameex would open epsxe and then go right back to gameex
  • 7 months later...
  EMKO said:
:)  it works perfect now thnx
Yeah I was having the same problem myself, fixed now thanks to this proggy.
Cheers.....my htpc/cabinet is nearly done!!!! (after 5 months!!!)
All I have left ot do is go through all 600 psx iso's and create epsxecutor configs for them
  djrobx said:
Hi Tom,
EMKO,
-- Rob
djrobx: Perhaps this program can solve ALL emulation problems emerging from .lnk/.bat/.ahk use? I see that you've added support for joy-to-key mappings. Any chance of adding AutoHotKey and AutoIt support as well? That would indeed rock and make PC/DC game through GameEx so much easier.
Tom, perhaps this project should have a sticky thread? So the non-noobs that want's to test it can report problems without flooding the GameEx forum?
Emph
Emph
Emph, just to let you know, DJRobX seems to be MIA.
I am sortof halfway noob....I used to be really techy but now I am getting older.
However making a batch file was easy enough...took me back to the good old days.
After stuffing around with mamewah this all seems too easy =).
Does this mean that nothing is happening with this? For how long has he been gone? I see people as MIA when a week has passed. ;)
Perhaps he hasn't been posting here because he's busy working on this app? ;) *crosses fingers*
Emph
  EMKO said:
you dont need this program anymore this was only a problem in the older gameex version
Yes, YOUR problem was in older versions. But I still have issues with loading of auto-hot-key scripts and disc image mounting. And I know for sure that I'm not alone. :blink: See here: http://www.gameex.info/forums/index.php?showtopic=1173
Also, djrobx has a very nice manner and some of us miss him.
Emph
Emph
I miss him too emph. I mailed him a couple of times, but got no response. So I removed his moderator status as a security measure. He's likely just got very busy. At least I hope it's that.
Emph
umm u dont need to mount any images even if u just use epsx u send a command same with epsxecutor
this is the command
-loadiso
here i made a screenshot
you do that for each game u config
make the .lnk files make a cmd.exe files in the same directory as your .lnk files
you need to config it to what you like and its also good for games like final fantasy 7 where u have to turn on that one patach
