For some reason after the upgrade none of my mame control settings seem to stay. Im talking about the analog controls. If i set it to 55% when i leave the game and go back in its back to deafult(35%)
any suggestions?
any suggestions?
I dont think this has anything to do with the upgrade. GameEx has no influence over MAME settings other than what you put in the command line. Have a think what else you did.
Also, if you saved the settings using MAME32, they wont be used when launching MAME32 from a command line. You need to use a mame.ini file, or specify the options in the MAME Command line in GameEx Config.
