I just found my favorite dos game of all time willy beamish.
I downloaded dosbox to play it.I have it installed to c:\dynamix
I have the cd-rom mounted to Device 0 e:\
I am running c:\dynamix\willy.bat
willy.bat contains the following
@echo off
E:
willy C:\wcd\resource.cfg
In dosbox I am doing the following command
mount c c:\dynamix
then willy.bat
The game ran Once, perfect, I shut it down to change the rez on my monitor so it filled more of the screen, now when I run willy.bat dosbox just freezes immediately, I rebooted, same thing.
Anyone with dos box experience have a guess why it would just stop working? This is my first time using this program.
thanks!
@echo off
E:
mount c c:\dynamix
then willy.bat
thanks!
I use d-fend FE for setting up dosbox games... It works great! Once you go throught the wizard for whatever game you want all you do is create a shortcut to the config and tell gameex to use *.lnks.. Works great for me.. If you are not sure how to setup gameex to use shortcuts just ask.
Check this post for the said app
http://www.gameex.info/forums/index.php?sh...amp;#entry25979
thanks brian, downloading d-fend now, problem is though dosbox is freezing on this game standalone, even without gameex but I will try this.
With the Fe you can specify what type of video mode,hi mem,amount of memory to allocate,soundcard to emulate,etc etc etc...
Also the game might have a CFG file that might need to be recreated..
I just downloaded willy beamish by sierra.. It works great.. Iam attaching my config for d-fend just import it and change the path to the game exe..
Once it works you can right click and send a shortcut to the desktop.
Thanks brian, worked for me too, must have been a setting or something
