hi there,
Thanx for the arrival of gameex tom, it is cool, slick and great idea.
however i have a problem, my roms make a total of 2.5 gig thats mame alone, when i try and update list i get to about 2% and it hits 100% CPU and then all i see is a box saying 15/60 in the title.
i tried to load just 10 games, and this did work but i dont have 10 games, i have over 2000 games.
i also have 750 snes games, what emulator is supported (snes9x or zsnes)
and last but not least, my make snaps has gone, i dont know where but the option in the menu is no longer there or i cant find it.
regards
minus4
p.s problem is on both machines, over 1 gig CPU and 1 is win2k other is win2k3.net
1) No games: What version of MAME do you have? This could be the problem if it isn't a newer build. Also, check out the filter settings for MAME. "OnlyWorking=False";"AllowImperfect=True" just to see if anything more pops up.
2) SNES emulator: Anything you want. I've used ZSNES with no problems.
3) Snaps: In the config utility, under "Enable/Disable Features" is "Hide Create Snaps." This should be "no."
-Matt
thanks for repy i sorted the problem, i had 4000 games, so i went into config
i changed the sleep to 8 and then asked it not to verify the roms.
once that was done and i had a list, i then ran catver.ini, to filter into cats
i then asked it not to show clones or the porn roms :P hehe
and that seemed okay.
i have a new problem now, but i will ask in a new post aswell.
when on jukebox, screen goes black, like gameex goes into screen saver, but its blank and there is no options to have one or not...... and then it takes about 5 mins to get back and sometimes i see the screen with title -quick
i do not have screen saver enabled on the system either.
