I run an arcade monitor in my cab, my whole gameex and emulators are set to 800x600 resolution, If an emulator uses something otherwise you have to adjust the V-HOLD on the monitor to play, which noone wants to do.
FREEDO runs apparently at a default 640x480, Does anyone know if there is a command line option to force 800x600 rez for this emulator?
UPDATE: I ended up just switching everything over to 640x480 so no need for help. thanks
