Minimizing Problem..
Guest dmitri
GameEx minimizes to the taskbar on start (shortly after displaying the menu). I'm forced to alt-tab back and continually click to ensure focus is maintained on GameEx. Once I"m past this start-up routine it runs fine - except AVI playback. On playback completion, instead of returning to the menu, it minimizes.
I have no applications running in the background that might interfere with GameEx. I've tried windowed and fullscreen modes. No difference. Any ideas?
GameEx minimizes to the taskbar on start (shortly after displaying the menu). I'm forced to alt-tab back and continually click to insure focus is maintained on GameEx. Once I"m past this start-up routine it runs fine - except AVI playback. On playback completion, instead of returning to the menu, it minimizes.
Do you have any programs that run on startup?
If you have a startup video try disabling it.
Try Changing themes.
  • 4 weeks later...
Just thought I'd report back.. After trying everything shy of a fresh install of windows, disabling Nvidia's Nview desktop manager solved the problem.
Thanks for the tip... :)
