Tomorrow I will get my J-PAC for my arcade monitor, I am going to use Soft 15hz for my program to operate the Arcade monitor, As far as gameex goes, is there any settings I should change for it to look good or operate properly, I notice there is an option for ARCADEVGA card from ultimarc, should I turn this on if I am using an arcade monitor and not the actual arcadevga card?
Thanks, I never hooked up a arcade monitor to a PC so this will be the first time, not real sure what to expect, or what order to hook it up.
